Front wheel grinding noise
So I've been having trouble with my 4wd on my 09 fx4. About a month ago the 4wd quit engaging so I took it into the dealer and they diagnosed a bad IWE solenoid and bad actuators on both wheels. I get the truck back after having them replaced and the 4wd shifts fine, however I have now started noticing a loud grinding noise under throttle (very bad when pulling a hill or towing) seems to be coming from the passenger side front wheel. I took the truck back in and had the 4wd looked at and they couldn't find anything wrong with the vaccuum system or anything. I'm at a loss. Could it be the wheel hubs causing the grinding? Im almost positive it is a 4wd issue because when I put the truck in 4x4 the noise stops.
If they changed a solenoid and both IWE's, you should have a 12 month/12k mile warranty on their work. Take it back and push them a little harder - that grinding is the IWE partially engaging under low vacuum conditions. There is something definitely wrong with the vacuum system and the new IWE is grinding itself up.
So I took it back to the dealer, this time to a different (and bigger) Ford dealer than the one in my home town. I told them everything that it was doing and it ended up being 2 bad check valves in the IWE system. All is well now thankfully. After much research, I was pretty sure it was the check valves because it was losing vacuum under throttle (which is what the check valves are there for) but I didn't have a vacuum checker and couldn't find one at any of the local parts stores so I figured it would be worth the $50 or so odd bucks to just take it to the stealership.
