rear tire wobble
rear tire wobble
hello im I need of some help I have a 2010 f150 with 8.8 355 non limited slip my problem is my left rear tire wobbles and wearing inside of tire the tire acutally leans in at the top neg camber. I caint seem to fiqure out why. ive replaced all axle bearings and seals replaced left rear axle shaft and spyder gears and damn thing still wobbles. could my new ford axle shaft be bent I didn't check it I assumed it would be ok since new from ford. ive been told could be bent axle tube but axle shafts come in and out fine ive rotated tires not bent rim so I am at a loss so any help or advice would be a blessing .
thanks scott
thanks scott
thanks for reply but it is not leaking around the flange at all and I have checked the weld numerous times I do not see any indication that its bent or cracked im at a serious loss here and its a real headache going down the road he tire makes noise at low speed and its driving me nuts. when I jack up truck on jack stands and leave tire on with brake and rotor attached its barely noticeable but when I remove everything and mount tire just to axle shaft I see the wobble very pronounced, any ideas
It's a weird one for sure. Why not get a used axle for it? It's a solid rear axle, so the only possible cause of negative camber would be a bent housing - which would be caused by a previous collision of some sort.
Probably not the answer you want to hear after dumping money into your existing one, but that's what it comes down to.
Axle housings are not as strong as most think and not unusual to see one not perfectly straight. If you can get a perfectly flat surface( alignment rack comes to mind) careful measurement should reveal the culprit. Our aligment eguipment will show this during a 4 wheel alignment.I know you can't adjust the rear but 4 wheel alignment shows problems as you describe in addition to making sure all wheels are tracking together after adjustment of the front. Find a GOOD alignment shop with up to date equipment and you won't have to guess and throw parts at it.
Wobble
update
The wobble sis figured out with the hub off and tire mounted to flange the flange has a bevel edge and it ****s wheel making it wobble put on rotor no problem. Measured with run out gauge all is good. Ford says the camber is not uncommon so . My problem is I still have the whirring noise like bad tire upon accel and decel most prounounced between 15-40 mph my ace mechanic and I checked it out he believes I have worn Carrier bearings or pionion bearings or both so guess I will do both soon as I gather parts I hope I can accomplish this I've read many threads think I can. Any ideas or pointers thanks
Left rear tire wobble
Hello I know this is an old forum.Did you have to replace the stock rotors with aftermarket rotors to get the wobble out? Didn't quite understand.
The following users liked this post:
A wobble is not a lean.
A wobble is not going to be caused by a bent housing, but lean (camber) is.
A wobble is caused by a wheel bent or a bent axle where the mount surface is not exactly 90* to the axle shaft from wheel bearing to carrier end.
A wobble can be caused by a rock or other obstruction between a wheel and the rotor preventing a wheel from proper seating.
