Fuel Pump Driver Module Question
Just give it light coat of Fluid Film and inspect it seasonally when yer doing the spare tire and winch assembly maintenance that everyone does 4 times per year
MGD
Wow! I am glad I found this and the how to.
https://www.f150online.com/forums/el...ontroller.html
I love this forum. Thanks guys. I hope I was able to fix this before it got worse. I cleaned up my fuel pump driver module, wiped it down with a little lubricant and raised it up off the cross member.
Before
Corroded underside
Cleaned underside. I didn't want to pick at it for fear of putting a hole in it.
Reinstalled
Before
Corroded underside
Reinstalled
Sure you got the right one?
It's still a cast metal base ( though it's powder coated )
http://dormanproducts.com/p-48472-590-001.aspx
MGD
Wow,
Dorman shows that being used from '04 to '11.
My wife has an '06 explorer w/the 4.6, are there any other models w/a similar issue? My understanding is that it is only an issue of dissimilar metals corrosion and being located in a harsh environment. Is this true?
The cast metal backplate requires no dissimilar metal contact to corrode - simple exposure to road salts and moisture will do that all on it's own. The other contributing factor is the direct contact with the crossmember - spooge gets trapped - further promoting corrosion. Hence the standoffs.
Dorman may powder-coat, but the factory does not. Ergo the use of fluid film.
MGD
Have you used Fluid Film on anything else?
I've been thinking of re-doing my chassis. The new salt they use on the roads is causing orange oxidation. I'm trying to motivate myself to get started with the POR15 system (sanding, metal prep and por15). I don't think the chassis will get much sun so I won't be using any top coat on it. Maybe a rubberized undercoating out of an aerosol can as a final stage.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
Folks have their preferred methods - this just happens to be mine. The only other feller I hear routinely mentioning this stuff is Truckguy24, in MA.
Difficult to weed out those posts from all the billions of Plasti-Dip threads. You'd think the Vatican was endorsing the stuff
MGD
Yep - everywhere except the brakes and exhaust. I also shoot it into the little holes in the doors, tailgate, etc. It ain't a lotta fun, but I just buy those disposable full-body alien invasion suits from Princess Auto, and lay down a big tarp and drive over it. Remember to remove the spare. And wear googles or a face shield. And nitride gloves.
You should inspect the FPDM quarterly if possible - the spare & winch & winch lock should be serviced that often anyway IMHO.
MGD
