Should i remove the front diff cover to change fluid?
yes, you should remove the cover..... it is good engineering practice.
this way, you can not only ensure that all fluid is changed, but also get a good inspection of the gears while its open. there isnt a gasket, just use some good RTV, allow it to set up a bit, and refill with the new fluid.
Well that makes me feel better, I just drained it and topped it off with new amsoil. So far so good
Adding the Amsoil, you'll never have to change that fluid again!
