IWE's? Loud grinding from front end.
well i thought i had the problems fixed when i changed i iwe soleniod but it started making noise again last night
i did all the vacuum checks and could not find any leaks ( i did find and fix 3)
so i just ordered new iwe hubs and vacuum line kits going to pick them up, the small line with the check valve will be in on monday
will post update
will post update
well today i was doing another vacuum test and found another (2) holes in the hard line going around/ under battery tray
funny thing is all the holes im finding are not rubbed, they are all soft spots in the hard tubing peices like a chemical is softening them up, i've used nothing under the hood since i've owned it
so i ordered a new line set (complete)$75 bucks and new iwe's for both sides($120 each) becouse at this piont i'm sure the existing has got to be damaged
i'm just holding my breath as to what extra i find and have to fix when i start into the iwe's
If you guys want to wander down to the 2004-2008 forum and use the "search" function, you'll find everything you ever wanted to know about the IWE system and its problems (and fixes) in some posts by TNF150. Working from his posts, I fixed all of the problems on my 2005 myself and saved a fortune.
