permanent fix for 4wd vacuum IWE
Old 04-06-2010, 11:54 PM
FirstTimeFord's Avatar
Ok I may be way off here, but Ford is the only one who has the IWE system, everyone else (Chevy, Dodge, Toyota) Just has the front drive shafts connected directly to the wheels, meaning everything is still spinning in them to! so in other words you plug the lines you just make it like every other truck take the lose of 1-2 miles per gallon, and there you go, I dought it would hurt anything!
Old 04-12-2010, 08:57 PM
DonJacobs's Avatar
Folks - I have read thread after thread on the IWE dragging noise and took the easy, least expensive option first - I replaced the vacuum solenoid. I had the noise almost all the time and thought this cured it. After about 2 miles and a 90 degree right turn, the dragging sound of gears trying to engage came back and is just as frequent as before. Well, the $25 experient was not a bad experience. Does anyone suggest next steps for troubleshoot / repairs this before I do-in my entire front end?
Old 04-15-2010, 11:23 PM
tbear853's Avatar
Vacum leak either in a line due to cracked end or rubbed hole ... or an IWE itself is leaking faster that the engine vacum keeps up. You need hose and a vacum pump, check each IWE and see how well they hold vacum ... then inspect lines.
Old 04-15-2010, 11:32 PM
tbear853's Avatar
Question
Originally Posted by wildvodka
Thank you for the input so far guys! This is really encouraging.
@Tbear - one of the things I looked at before I read about the IWE was the "posi-lok" system made for previous generation f150s. It replaces the vacuum actuated system that engages the front drive shaft with a pull cable that gets routed into the cab.
Now, for your particular scenario I think such a system could be worked out if your were comfortable with some fabricating and making some permanent changes to the IWE system. It might be possible to rig up a system that pulls or pushes the IWEs in and out with a cable. Essentially the way that a mechanical parking brake works. Its a cable running to a center mechanism between the two wheels that pulls or pushes on the two sides equally.
With such a system the 4wd computers would all think everything is working fine, solenoid and all the vacuum stuff is still intact, just not hooked up to the IWEs. Instead the IWEs are manually controlled from the cab.
This would be the "next step" after seeing how simply locking the hubs by disabling the vacuum system works. Locking the IWEs is simple, just plug em up, but this would require some fabrication and more knowledge of the internal IWE workings than I have. But I'd love to see someone try it! Heck, make it a kit. I'd buy one.
Cheers!
Re: "posi-lok" system made for previous generation f150s
Wonder if they'ld fit the '04 up trucks ??? (anyone reading this, that's a question, not a statement)
I understand parking brake cables and equalizing linkage or levers.
I wish they just had manual hubs.
Old 04-30-2010, 04:30 PM
DonJacobs's Avatar
Well I've got good news. I picked up a decent ($20) vacuum gauge and tested my system at the manifold, the solenoid, and both IWEs. It showed a very stable 21 inches all the way around. Knowing that and my history, I took my findings to a very reliable independent shop here in the Lehigh Valley and explained things. They tested and validated the findings, put it on the lift and spun the wheels until they got the noise too. They replaced (only) the passenger side IWE and I have been golden for more than a week now. If you live in the area and want the name of the shop, contact me. We use them for our ambulances and trucks - which is how I came to know of them. They are a real gem and extremely reasonable. I paid $303 for their parts and labor, including tax.
Last edited by DonJacobs; 04-30-2010 at 04:35 PM. Reason: spelling errors. (Haste makes waste!)
Old 05-02-2010, 10:44 AM
Jackp212's Avatar
Got my 2010 with 2400 mi back from the dealer they changed the IWE and front bearing hub assembly under warranty. Lets see if I need the permanent fix down the road.... Hope NOT !
Old 05-03-2010, 06:15 AM
DonJacobs's Avatar
I thought thie IWE replacement was the permanent fix. What's is the permanent fix?
Old 08-12-2014, 11:28 AM
Last Forever's Avatar
Reviving an old thread. After 10 years and 140,000 miles I finally had the IWE vacuum issue. Needed to keep driving but stop grinding. Pulled the vacuum line from the intake as suggested by this thread. Great solution. Front end (shafts, axle, differential, drive shaft) rotates - whatever - the transfer case is disengaged.
I will give it a whirl to properly fix when its time (Nov) for winter tire changeover and I have easy access to everything. Will get the kit from Ford ($130) and swap out all the vacuum lines.
Old 06-30-2019, 09:40 AM
Taylor95's Avatar
Vacuum
Hey all, I was following a thread on the IWE problems associated with leaking or otherwise malfunctioning vacuum system, and I had a question about a permanent fix.
Has anyone tried simply disabling the vacuum system entirely? You can block or plug the vacuum line at each IWE, which will permanently lock them.
So hear me out...
By locking the front hubs permanently you will cause them to always spin the front axles, and turn the front differential. However, unless the truck is actually in 4wd mode the front diff gets no power supplied to it, because the front driveshaft is not engaged by the transfer case. So, you will get increased drag, which may adversely affect MPG, and there is a slight possibility that you will lose some performance due to drag on the front wheels. However, I can't see that it would be that bad. Certainly it wouldn't be any worse that the pre 2004 models with 4wd, right? Because that is essentially how their systems operate.
My understanding is that the IWE are only there to decrease drag on the front drive train when in 2wd to increase fuel economy.
From reading the document on "principles of operation" for the Ford 4wd system, it seems to me that two things happen when switching to 4wd. First the transfer case shifts over to engage the front drive axle, while it does this it also uses a clutch to make the front drive axle match the speed of the rear drive axle. If the axle is already turning because the front hubs are locked, then this should be unchanged from standard.
Then it locks the front hubs using the IWE. Since they are already locked, this step is unnecessary. There would be no need to change any components, the vacuum system would still go through the steps to lock the IWE, just nothing would happen.
So what you would be left with is a system that only has the transfer case and its components as moving parts when switching to 4wd. No worries about water in the system, no problems with vacuum leaks.
It just seems to me the IWE system is superfluous, it serves no purpose other than to make the system more complex and unreliable. All for a gain of maybe 1-2 mpg.
So, concerns that I have are driveline wear, and increased drag. Drag isnt the biggest issue, I could live with slightly lower MPG. But if it caused significant loss of performance, then that could be an issue. Driveline wear is a biggy. Potentially you could have problems with the transfer case if the order of doing things is messed with. It is supposed to get the front shaft sped up, engaged, get the axles spinning, and THEN engage the hubs. So I don't know if this would cause problems or not.
So this is my idea. Anyone tried this, on purpose or by accident? Anyone who has not tried it but has some technical knowledge want to chime in?
Cheers!
What about coming up with your own vacuum supply. Get a vacuum pump of some kind and run your own vacuum lines to the 4x4 actuator (IWE) and have a switch inside the truck to turn off the vacuum when you switch into 4wd
Old 06-30-2019, 03:05 PM
tbear853's Avatar
If the engine is running at all, you have vacuum.
As I recall, the issue with IWEs was vacuum leaking while one was moving down the highway and the IWE trying to engage while rotating at speed. Wouldn't disconnecting and capping lines not just let IWEs to engage and stay engaged …. and all be OK as is on a Harley or Limited truck? There isn't any IWE feedback sensors, the system only knows it closed vacuum to them when going to 4WD? Am I wrong?
I haven't given up on my idea of switching vacuum separately so I could use 4wl on TC without actually engaging IWEs, but just haven't gotten around to it yet. No real need for me. When I mentioned it way back in 2010 in this thread, I was considering camping, but not gonna happen.
Old 07-22-2019, 11:41 AM
vigness's Avatar
Hey all, Trying not to hyjack, but I'm scratching my head.
Working on my 2005 F-150 4x4. Had a grinding noise from the front left, bad IWE. Been there done that. Thankfully it was locked out ( free wheeling ) so I kept on trucking.
Finally had some time to order a pair from Rock Auto and get to it. Got it in and tested it... and it's not releasing on engine start. Jacked up the right side, and same thing. Okay, get out the vacuum gauge ( which I should have done in the first place ), and no vacuum in the IWE. So now it's time to start tracing the vacuum system...BUT I CAN'T FIND A DECENT DIAGRAM TO TELL ME WHAT IS WHERE!!!
I have the 'control unit' on the frame just in front of the left wheel, but I seem to remember something about another solenoid somewhere on the fire wall. And since the fittings on the 'control unit' are threaded in I thought I'd check at the solenoid first... if I could figure out which one in that mass of wires and hoses it the one I'm looking for!
Can anybody point me to a good diagram of the 4x4 vac system, or at least tell me what I'm looking for?
Old 07-22-2019, 11:59 AM
vigness's Avatar
Thanks to all that considered this, got a reply on another forum. Found the solenoid right behind the battery. Yep, it's toast. Bypassed until I can stop and pick one up.
Old 01-13-2021, 12:41 AM
Angel Damage's Avatar
Iwe
So hear me out...
Cheers!
Mine malfunctioned and stayed in four wheel drive but the transfer case was in 2x4 and it was hard to control
Old 01-13-2021, 12:56 AM
vigness's Avatar
The front diff is limited slip. Being normally free spinning and never actually slipping, it is VERY limited slip. It's an easy part to replace. Wheel off, top ball joint, tie rod end, axle nut, and the three little 5/16" screws that hold it in place. Even hunting down my 21mm socket it only takes me an hour. I have an '05 and have replaced them twice. Always do both of them, and Rockauto has them reasonable, $50 to $75 each.
Old 01-13-2021, 02:14 PM
tbear853's Avatar
Maybe in your truck, but I don't believe it's limited slip in mine.
Quick Reply: permanent fix for 4wd vacuum IWE
