F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 11-06-2009, 07:19 PM
Vehicle: 2000 FORD F-150
replaced u joint tuesday and now have vibration
tuesday night i replaced a horribly worn u joint on the rear of my rear driveshaft (differential side) and now have a pretty bad vibration, i followed instructions according to the haynes manual, marking the position of driveshaft mounting to the yoke, and replacing it to the same position. the replacement was pretty strait forward ( i thought). and now i have a strong vibration at 65 - 70 mph that is deffinatly coming from the rear. i jacked the rear of the trick off the ground and put it in drive to look at the drive shaft and it is certainly not turning straight. i have the u joint in evenly in all four sockets (the clip is seated in the groove on all of them) so i am assuming that the joint is centered. what else can i check, could it be tha u joint??
truck is a 2000 f150 4x4 9.75 rear
thanks for any help
Old 11-06-2009, 08:54 PM
Vehicle: 2009 Ford F150
did you try clocking the drive shaft??
Old 11-07-2009, 10:25 AM
you mean checking the run out with a dial gauge, i didn't try that yet because i dont have a gauge, that may be next on the list
Old 11-07-2009, 03:13 PM
no rotating the drive shaft on the differental flange, it can bolt up more then way, just unbolt it and turn it 90 degrees, drive it and see if it gets any better, then repeat... or putting hose clamps on the drive shaft to try to balance it, or take it out and take it to a drive shaft place and have it balance...
Old 11-08-2009, 07:25 PM
Vehicle: 2002 Ford F150 FX4
just turn the shaft 90 degrees at a time until the vibration stops.
unless you saw a weight fall off while doing the u-joints then that is the only problem. next time make an alignment mark on the driveshaft and differential
2002 F150 FX4. Black two tone. Extended cab.
-SI/DO flowmaster catback
-AFE cold air
-EDGE Attitude. Level 2 Custom.
-Headmaster Shorties. One cat for each side.
-305/70R16 ProComp Xterrains-16" American Racing rims.
Old 11-08-2009, 08:05 PM
I did this old my old ford and dropped the driveshaft and one of the weights fell off .. It was a booger I had to take it out and have it rebalanced .. but The thing was mint when I put it back in.. Way better than it ever was no vibration at all.. .. This 2003 Ford Fx4 has never rode as good as my old 1993 f150 ( it does look better though )
John B
2003 FX4 5.4L K&N Cold Air, and Other Stuff
Owner of
B&R Fire Protection
Old 11-09-2009, 01:43 PM
glc glc is offline
Vehicle: 2003 Ford F150
You may want to pull the driveshaft and take it to a driveline shop, make sure it's not bent and get it balanced.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 11-09-2009, 11:25 PM
i know when i did my u-joints a huge frickin weight got knocked off. took it to a shop and the guy welded pretty much two washers on. surprised me that it took such little weight to re-balance.
-AFE cold air
Old 11-10-2009, 01:41 AM
yeah i think i am gonna need to get it balanced, i did mark the original placement of the shaft before i removed it and put it back in the same position. who would i take my drive shaft to for balancing?? not your average mechanic i assume, a trans shop??
Old 11-10-2009, 08:12 AM
glc glc is offline
These guys anywhere near you?
http://mrdriveshaft.com/
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
