F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 10-19-2009, 11:25 AM
Rear Diff Gasket maker question
I haven't found any info if you put the gasket maker on both surfaces or just one. Do cooler temps result in slower curing times? Highs are in the sixties. Do you assemble the plate partially onto the rear diff to squeeze out the gasket maker before it cures? I'm using the Permatex black. Any suggestions would be greatly appreciated.
Old 10-19-2009, 03:20 PM
Vehicle: 1997 Ford F150
I've only put it on the cover. Let it tack up some and then install, only finger tight on the bolts. I let this sit overnight and then tighten the bolts in a 'star' pattern to evenly distribute the seal. I don't tighten to the point where the sealer starts squirting out of the sides, just until I see it on the edge.
It's still hit and miss for me on this too! Sometimes it works, sometimes it leaks!
At least having only the sealer on it makes for easier cleaning of the surface next time!
Good luck!
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 10-19-2009, 10:49 PM
Vehicle: 2002 Ford F150 FX4
from what i've heard:
make sure all mating surfaces are clean.
apply to either the diff or the cover. i think the cover would be easier.
finger tighten bolts until seal starts to squeeze out. let this sit until it sets up then go back and tighten to spec.
2002 F150 FX4. Black two tone. Extended cab.
-SI/DO flowmaster catback
-AFE cold air
-EDGE Attitude. Level 2 Custom.
-Headmaster Shorties. One cat for each side.
-305/70R16 ProComp Xterrains-16" American Racing rims.
Old 10-20-2009, 04:07 AM
glc glc is offline
Vehicle: 2003 Ford F150
Or, you can always go get a real gasket.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-20-2009, 09:32 PM
Vehicle: 98 F1fity
i use black rtv silicone.. clean both surfaces apply to diff housing.. put cover on and run em down with a 3/8s impact in a star pattern.. say what u want.. i havent had one leak yet...
Old 10-26-2009, 10:32 AM
Quote:
I ended up using the Permatex black,cleaned both surfaces,applied a generous bead to the cover,reapplied the cover till it just started squeezing out,let it sit for an hour then torqued the bolts and let it set overnight before filling with lube and so far (knock on wood) no leak.
Old 11-16-2009, 08:42 PM
Well I did this and used RP Gear oil .. I heard it already has the friction modifier in it .. I will do a test drive tomorrow .. I went with the real gasket cost me 6.00 at autozone..
John B
2003 FX4 5.4L K&N Cold Air, and Other Stuff
Owner of
B&R Fire Protection
Old 11-16-2009, 09:21 PM
Vehicle: 2009 Ford F-150
Send a message via AIM to trk35 Send a message via Yahoo to trk35
The reason why a silcone made gasket leaks is because either or both of the surfaces were not cleaned good enough. I have always used "brakecleen" to clean both surfaces before I applied silicone to just one of the surfaces. After I applied the silicone, I tightened the bolts to the proper torque spec and then filled with fluid. I never had one leak if I cleaned it properly.
Old 11-16-2009, 11:10 PM
Quote:
go ahead and add the friction modifier. no other oil manufacturer seems to get the right modifier or not enough in their oils. always best to add ford's friction modifier when the application calls for it.
Old 11-16-2009, 11:14 PM
OMG Cheif FX4 ... I gotta smell that green skunk Stuff again.. It to almost a week do get the smell out of my driveway when I spilled a little on the concrete... Oh well I will put it in .. Better safe than sorry..
John B
Owner of
B&R Fire Protection
Old 11-17-2009, 02:04 AM
Send a message via ICQ to Klitch
Good luck!
Mitch
i usually do what is said here with cheap rtv, the one time i used "the right stuff" it was a sob to get it back off but did not leak.
let her sit for 15 mins or so til its not just a goo, and finger tighten it. come back the next day sometime and snug em up.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 11-17-2009, 06:38 PM
One thing to consider is that the fluid in the rear will continue to slowly drain and can contaminate the sealer. If I ever remove a diff cover again, I'm using a gasket. The synthetic fluid is too expensive to dump and replace again just because the rtv didn't seal properly.
Roadie
2002F150LariatFX4Supercab5.4L
Old 11-17-2009, 11:08 PM
pump it out roadie, reclaim it. its ok.
Old 11-18-2009, 01:12 AM
Vehicle: 2007 Ford F150
Just use the Permatex, use it nice and heavy around the lip, press it up, and tighten it. If you want it to look neat, get a shop rag and go around the lip a few times from the ooz it produces.
Just wait about 30 minutes, add the gear lube and 5 oz of friction modifier (if you got LS!) and wait about an hour or two for the RTV to really cure well.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
