Quote:
Originally Posted by jose_bigred
So i want to put a posi locker in my rear end.
I have the 8.8 housing i think lol.. my truck is an 08 f150 4.6 2v and only pulls with one tire! sad
Will adding the posi locker help with better take off at WOT???
1). Unless it has been changed by someone, your '08 F150 4.6L has the 8.8" rear axle with 31 splines.
2). A posi and a locker are two separate things. A posi, also known as a limited slip differential will provide power to both rear wheels under most conditions, yet it still allows them to turn at different speeds to negotiate corners smoothly. A locker is a more aggressive traction aid that will provide power to both wheels under pretty much any condition, but is less forgiving on the road than a limited slip. To answer your question though, either one of these will help get the power to both rear tires. If you had problems with traction before, I would imagine a limited slip (posi) or locker either one could go a long way towards helping you.
