F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 10-10-2009, 05:07 PM
Vehicle: 2004 Ford F150
Info needed on 4wd vacuum actuator/sensor?
2004 lariat S.crew 4x4--this morning, a sound in the rt front wheel area directed me straight to the mechanic, after a search and spinning the rt frnt wheel freely, sounds as if it is trying to engage into 4wd (the switch is in 2wd also). My first go round w/ this. Mechanic tells me it is the vaccum actuator sensor if i am correct. Removed the vacuum line and there was some slight suction too, on both lt/rt, is that normal when in 2wd? Question is, is this common, do both lt and rt get replaced or individually or one unit only. Is it a easy fix to do or let mechanic do it...is it costly too? thanks for any feedback...
Old 10-10-2009, 05:20 PM
Vehicle: 2006 Ford F150
Quote:
I had vibration and turns to be that a vacuum leak the mechanic put a new right line and problem solve, check lines to see if they are broke good luck.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
