F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 10-09-2009, 04:26 AM
Vehicle: 2009 Ford F150
3.55 gears with 33's?
I was just wondering if any of you guys think it's worth re gearing 3.55's for 33" tires. I got the 9.75 LS in an 09 which I tow/haul with a bit and would like to purchase some 285's. Thanks
Old 10-09-2009, 04:28 AM
Vehicle: 1994 F150
probably not necessary for 33's...depends on how much you tow.
Old 10-09-2009, 08:38 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
Quote:
Originally Posted by begirbat View Post
screw you spammer, if this wasn't a family friendly site I'd tell what I think of you here, but I'll take it to PM...
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 10-09-2009, 08:39 AM
Vehicle: 200? FORD
Quote:
I'd regear to 4.10's unless you plan on a larger tire in the future, then I'd go with 4.56's or 4.88's
Old 10-09-2009, 09:00 AM
Vehicle: 1998 Ford Expy 5.4
Send a message via AIM to Camarothatcould
eh.... its not too bad...
the Lead sled
Swapped 5.4. . . cause 4.6's are only good for taxi's and boat anchors. . .
Old 10-09-2009, 12:08 PM
glc glc is offline
Vehicle: 2003 Ford F150
If you have the 6 speed auto, you shouldn't have to regear.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-09-2009, 12:56 PM
APT APT is online now
Vehicle: 2003 Ford F-150
The 6-spd should help for the city. not sure you'll like the down shifting on the highway, though. What kind of trailer and weight do you pull?
Old 10-09-2009, 01:26 PM
Vehicle: 2006 Ford F150
It's not the best setup in the world but if you aren't gonna be pulling anything too heavy then you should be fine. If you got the budget I'd get 4.10s though, more torque is never a bad thing
Old 10-09-2009, 04:17 PM
I have run 285's on other trucks here's what I found. If you run a 6 or 8 ply tire, going from the 275/65 18 will be a marginal difference at best. If you are going to a 10 ply tire, at highway speeds little or no difference, but at start to speed there is a noticeable difference due to the added weight of the tire. As someone else said, if you don't tow alot or often, you will most likely be okay with a 6 or 8 ply tire and gearing would not be an issue for 285/65. Larger weight more often, then 10 ply tires would be in order, but aside from some sluggishness at start, shouldn't be a big deal. 4.10's are good, but if you drive highway alot, you may consider 3.73's as a more efficient gear considering you won't be running 35's. Just my opinion, hope it helps.
2009 F150 Lariat Screw 4X4
Old 10-09-2009, 08:51 PM
Vehicle: 2002 Ford F150 FX4
in my 02 i have 3.55 gears and 33s. my boat is probably about 2000 lbs and the truck pulls it fine and has no problems getting it in and out of the water. kinda sluggish getting up to speed but i really have no problems. would be nice to have a set of 4.10s though.
2002 F150 FX4. Black two tone. Extended cab.
-SI/DO flowmaster catback
-AFE cold air
-EDGE Attitude. Level 2 Custom.
-Headmaster Shorties. One cat for each side.
-305/70R16 ProComp Xterrains-16" American Racing rims.
Old 10-12-2009, 07:07 AM
Vehicle: 1994 F150
3.55 to 4.10's is not really going to make that much of a difference...especially for the $1000ish its going to cost. Someone else mentioned 4.56 or 4.88 if you plan to go bigger, that would be more worth the $. But it's all just a matter of opinion, none of these combinations will hurt the truck. Good luck with whatever you choose.
Old 10-12-2009, 03:18 PM
glc glc is offline
Thing is, the 6 speed auto has a very nice low 1st gear. This compensates a LOT for the final drive ratio. If you have issues on the highway, you can always lock out 6th and maybe even 5th.
Old 10-12-2009, 05:24 PM
Vehicle: 2007 Ford F150
I would not spend that kind of money you will have to if you are only running 33s... Especially if it's a 4x4... Changing gears for tire size will be important for tires 35"s or larger...
Old 10-12-2009, 05:41 PM
Vehicle: 2005 Ford F150
I have 32's and 3.55 gears. It does just fine. No drag racer, but not a total dog. I can't see another inch making that much difference. As stated, with the 6 speed, you will be fine.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 10-12-2009, 10:28 PM
coming from 3.55s though, a 4.10 is a nice jump.
i know going to 35s a 4.10 is actually more than enough to compensate for the jump in tire, as far as calculations go 35/33 *3.55 = 3.765
-AFE cold air
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
