4wd ?
Old 09-17-2009, 04:11 PM
bigredrig's Avatar
4wd ?
Ok guys I have a problem and looking for some direction on what to do to fix it.
I'm having issues with my 4wd system. I turn my selector switch to engage my 4wd and the light on the dash lights up and I can hear the transfer case engage but my front tires don't engage. I took the lines off of the vacuum solenoids on the firewall and they have vacuum to them but don't think they have any going out of them. I can manually lock the front hubs in if i take the vacuum lines off the solenoids and use a vacuum pump. Does this sound like I need new solenoids? or what. By the way this is on a 2001.
Old 09-17-2009, 05:46 PM
kingfish51's Avatar
There should be vacuum to one of the solenoids while in 2wd, and when in 4wd, the other instead. Have you checked to see if any of the vacuum lines have cracks or leaks? If everything else checks out, it will probably be a bad solenoid.
Old 09-17-2009, 07:06 PM
jbrew's Avatar
Those lines tend to break between the battery box and firewall for some reason. IF that's the problem..
Old 09-18-2009, 12:13 PM
Speed-Racer's Avatar
It happen to mine also... Wynne Ford had to fix it so not sure.. they said something about a 4x4 modular valve or something look them like 30 mins to fix
Old 09-18-2009, 12:48 PM
kingfish51's Avatar
2008 and 2001 have a totally different setup. The 2 are not comparable.
Old 09-18-2009, 04:02 PM
jbrew's Avatar
Yea these have an actuator that sometimes gets locked up. If it not the solenoid as Kingfish (Marlin lol) suggests or the lines, - check the Actuator -
Sometimes they stick, you can free them up with WD40 and a cheap vac tool, -like a Mighty Vac -
Quick Reply: 4wd ?
