donrjuan....got the same damn problem with my 2001 SuperCrew...the picture I get in my mind when I'm trying to use my 4x4 is a broken chain in my transfer case and the sprocket grinding against it....I'm probably going to have to break down and take it to my mechanic atleast for a diagnosis, but the way it sounds it isn't going to be pretty, let me know if you find out anything and I will likewise.
Quote:
Originally Posted by donrjuan
I have a 2000 Expedition 4x4, 5.4 L. The 4x4 is the AWD, 4hi, 4lo type. When it is in a load (such as stuck in snow) and in 4lo/hi and you give it much throttle it will make a slipping, well a buzzing/grinding sound from the transfer case. When this happens the 4x4 is not working or the tires are not turning on the front any way. Also this will happen if you really hit the throttle from a dead stop in AWD mode. I had a mechanic friend tell me that it could be the vacuum actuator not working properly or even the fork that it operates may be bent. I have looked around and have not found any one discussing similar problems. Any ideas on this one?
