F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
  #31
Old 06-19-2009, 08:09 PM
Vehicle: 1999 Ford F150
oem limited slip isnt very great not sure about locker
"Project 1ton150" build thread coming soon keep an eye open
http://www.f150online.com/forums/sus...ere-we-go.html
  #32
Old 06-19-2009, 09:34 PM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
well i've got a partial line on a 10.5 for $600 plus s&h (unless my uncle will bring it on his way through) which is listed 3.73 with a locker. i assume its disc rear listed with the v10 motor. I should probably get front and rear matching at the same time to save time. maybe i can find 4.30 ratio with my 35" tires and not have to bother with 4.56 gears. this would save some time and effort, plus retain the tone ring idea without extra thought and labor lol
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
  #33
Old 06-19-2009, 09:50 PM
Quote:
seems like a good idea.
But you wont beable to get 4.30's in reverse cut for the front.
  #34
Old 06-19-2009, 10:01 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Here is what I know of the 10.25. Pre 1997 it was a full floater used on the F-250. In 1997 with the F250 HD it was still a full floating. 1999 Ford stopped using a 10.25 full Floating axle and switched to the 10.5 full floating and the Dana's on the SuperDuty. 1997+ it is used on the F-250 LD and F-150 7700# option and it is a semi floating axle.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
  #35
Old 06-20-2009, 01:27 AM
from what i see the 10.25 can run a 10.5 gear with a different master install kit? sounds like the housing is the same from either axle range.
wtf is the front axle? d60 or something ford got a hold of and made different? i seen one article on a f350 that called it a d50 up front. goofy looking and retarded design process. why would you neck down axle shafts to the same size as a d44 spline on a 1ton truck?
  #36
Old 06-20-2009, 01:32 PM
JMC JMC is offline
The only reason Ii can think of is that it saves money. You can then use the same knuckle as the D44? Why does ford use an 8.8 in the front of our trucks?
Regards
Jean Marc Chartier
  #37
Old 06-25-2009, 04:10 PM
well, i see the correlation.
i think im gonna do it as just a 1 ton 1999+ axle swap under my truck. question is which suspension should i do up front? i think coilovers are in order
  #38
Old 06-25-2009, 08:36 PM
as in SAS... id say go 4 link and coilovers
But if you go leaf sprung you could get ahold of Farmboy Fabrications he has a complete SAS kit for our trucks.
  #39
Old 06-25-2009, 09:29 PM
i think he wanted 3k for the kit tho didnt he? lol
  #40
Old 06-25-2009, 09:55 PM
i dont think its that much. The kit just got finished so the price is iffy.
I think you are thinking about the Fabritech kit which is junk. Id check into Farmboy Fabrications kit i doubt its 3k.
  #41
Old 06-25-2009, 10:06 PM
oh my bad your right i was thinking fabritech.
  #42
Old 06-25-2009, 10:12 PM
im gonna send you some info for Farmboy Fabrications.
the fabritech kit was a bolt on 4 link that was pure junk.
  #43
Old 06-25-2009, 10:54 PM
thanks for the info, i hope its a good price since this is not really planned in my budget this year. even though i do need to do something, even if it means doing a custom long arm ifs lol
  #44
Old 06-25-2009, 11:04 PM
i think with the weight you haul, and the amount of power your throwing though your drivetrain a 1 ton axle would be nice.
Id say around 8" of lift would be PLENTY to clear 40's if you set it up right. Cut out the IFS crossmember, and get the thing nice and flexy.
If not then id say 12" of lift (8" lift springs) and 40's
The amount of lift is alot different when doing this.
My rear springs are only 12" lift springs but im around 22" of suspension lift. front springs are 16" lift springs. I used a block in the rear cause im gonna do a shackle flip for more flex and i didnt want to have to buy smaller springs.
You have to account for the axle tubes, spring perches, and hangers into the amount of lift.
  #45
Old 06-25-2009, 11:43 PM
the rear i figure i could get away with the old block treatment for a while and use my alcan leafs which are 7" of arc. i only want as minimal lift as possible so i can still squeeze under my lance camper which is already up on 4" blocks to get under it comfortably now lol. so i was actually wanting to stick to 35" tires or so. maybe it will be 37
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
