F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 06-16-2009, 01:57 PM
Vehicle: 2004 FORD F150
Quote:
Originally Posted by JMC View Post
Don't underestimate the 9.75. It is a very stout axle. I blew up 3 8.8s before I replaced mine. The 8.8 is a joke compared to it. I have yet to break my 9.75. Look at what the lightnings are putting to the wheels. They hook and go. Get one with disk brakes and the calliper will hold the axle in place if you break one.
Leaving a broken axle in, using the caliper to hold it, will lead to ring and pinion failure, and maybe worse. Little chunks of metal are now floating around in your diff. Full float you can pull it out, and keep the tire on.
9.75 is nice. But far harder to find, and far more expensive, and doesn't have the aftermarket support it should (not yet anyways).
Dana 70-80 and a Dana 70 front.
Or 14 bolt front and rear
or 609's front and rear
ok, I am drooling on my keyboard again.
Old 06-16-2009, 02:02 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
GM 14 bolt is a full floater, and the 12 bolt is semi floater.
I agree with JMC, also the 9.75s in the superdutys run heavy loads day in and day out.....
FIDDY IS BACK HOME click pic!
J-mod
X Dynomax Bullets X 2 16" Efans X Custom Sub Box X Reverse Fogs
Old 06-16-2009, 02:10 PM
14 bolt comes in both, FF and semi.
9.75 is fine. They are decent rear ends, and would make for an easy swap, if you can find one. Easy swaps are always tempting.
Old 06-16-2009, 07:35 PM
Quote:
One more wonderful thing about 9"s...ya can buy an already setup chunk for dirt cheap.
I got mine setup with a full spool, with one run on it for less than the gears would have cost alone.
Old 06-16-2009, 07:45 PM
nice ! And ya, a 9" third is way easy to find around here ! Dime a dozen, where I would have to special order a 9.75, or go looking. Any rock I flip over I find 9", dana axles, etc.
Old 06-16-2009, 08:02 PM
lol pretty much.
They're like roaches hahahaha
Old 06-17-2009, 05:04 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
would d60 bearings handle 2500-3k payload plus whatever jumps on my hitch and not give me troubles?
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 06-17-2009, 01:56 PM
oh... the tone ring... mines a 97 so it only used for abs correct?
Did anyone mention of there was support for changing the 9.75 to a full floater even though that sounds expensive lol
Old 06-17-2009, 03:47 PM
Quote:
It could probably handle it. A Dana 70, or 80 would make me feel better though.
Dana 60 full float would be a better option then the semi.
Nope, you'd have to go custom. Like I said, the aftermarket just isn't behind the 9.75. Its not nearly as readily available.
Old 06-18-2009, 10:33 PM
since i said i would. here are the pics.
My personal favorite pic here.
Old 06-18-2009, 11:14 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Nothing a little sand paper won't fix. Yup, time for a bigger differential.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 06-18-2009, 11:16 PM
Shoot is that it??
Old 06-19-2009, 03:50 AM
lol but im in love with how that carrier bearing spacer fractured and the bearing cup only split in one spot.
Old 06-19-2009, 07:52 PM
Vehicle: 1999 Ford F150
nice carnage.
"Project 1ton150" build thread coming soon keep an eye open
http://www.f150online.com/forums/sus...ere-we-go.html
Old 06-19-2009, 08:03 PM
LOL thanks.
So i've hit a bottleneck with reasearching the 10.5 axle, 10.25 was pre 99 i think? im having a hard time with one thing, there is some listed with a oem locker. i cant find any good info on this?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
