F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
  #31
Old 06-22-2009, 12:50 PM
alright well i got a little more in depth with this thing today and i have a few more questions. first off i pulled the lines off the hub. put vaccuum to the hubs and it holds. so the seal is good. plugged the lines from the hub and put vaccuum on the it at the solenoid. didn't hold so i know i have a leak somewhere between the hub and the solenoid. now my next question, although i have vaccuum at the hub does it eliminate the possibility that it could be the actuator itself, or is it still possible that the actuator is bad but the seal is not? remember the grindin noise occurred long before the 4wd quit workin. if im losing vaccuum, the hubs should be engaged but they're not. i know i have to fix the leak, but why did the grindin stop if i still have the leak and the seals are holdin at the hub? sorry for the book.
  #32
Old 06-22-2009, 01:47 PM
Vehicle: 2004 Ford F150
Did you change the solenoid yet? If not you need to do that first. My hub held vacuum too but it didn't work. The teeth were in good shape too. But you need to change that IWE solenoid before you do anything else. You could have 4x4 working in 10 minutes.
  #33
Old 06-22-2009, 02:18 PM
okay well after further investigation i'm almost sure the solenoid is bad. the line isn't leakin i just had a faulty plug on the other end of the line. now here is the kicker. in 2wd with the vaccuum hoses pulled off, the axles turn, so the hubs are engaged. the whinin sound stopped which typically means the actuator is gone. i have a bad solenoid so why are the hubs engaging but no more squeeling sound? they're not bad if they're engaging and turnin right? can the solenoid mess up and do reverse which sends vaccuum to the hubs at all times vs takin vaccuum away?
  #34
Old 06-22-2009, 02:48 PM
I did the same thing on mine when I was fixing it. If you have the hoses off the actuator your 4x4 wont work, point blank. Change your solenoid like we have said for the past 3 pages. Then change your actuator out. I highly doubt your hub is bad as I posted previously. Many of us here have been in this spot and we know this problem when we see it. Are you not wanting to spend over a certain amount of money on this? Trust me when I say the actuator is easy to change out and its not that expensive.
  #35
Old 06-22-2009, 02:58 PM
well really just tryin to understand. but no i don't want to spend too much money because the truck is sold once i fix the 4x4.
  #36
Old 06-22-2009, 03:26 PM
It wont be over $200 bucks. Get the solenoid and actuator and replace them. Then say goodbye to your truck.
  #37
Old 06-24-2009, 11:16 PM
well i changed the solenoid and the actuator. still no 4wd. in 2wd it has the hubs engaged like the new solenoid is bad. i know this because with the old solenoid the hubs would stay disengaged. why would the old solenoid send vaccuum if it was bad. is there anyway to bypass the solenoid to see if its bad?
  #38
Old 06-25-2009, 11:11 AM
Hmm I'm not sure. Are all the hoses hooked up properly? And are they leaking at all?
  #39
Old 06-26-2009, 09:41 AM
the line must have had a little trash in it. shes working like a champ now. thank you guys for all the help.
  #40
Old 06-26-2009, 10:07 AM
You got it man thats what we are here for. Are you getting another truck or moving to something else?
  #41
Old 06-29-2009, 11:52 AM
deff. another truck. looking at a 4x4 dually. need somethin i can put a weldin machine in the back of. now just gotta get the weldin machine fixed.
  #42
Old 09-09-2009, 01:05 AM
Vehicle: 2001 Ford F-150
wingman4, did you ever find out what's up with the 4x4 in your Expedition???
I have the same problem in my 2001 SuperCrew....you described it down to a T.
Quote:
Originally Posted by wingman4 View Post
hey you know our 98 expedition xlt 4x4 has a similar problem. You shift to 4hi and it reads it's in 4wd, but its not. I tried driving up a mulch hill so I could test it, and the back tires are spinning fine, but not the front. 4lo is similar, you shift to neutral, hear and feel it shift, shift to drive, drive up the mulch hill, but the front wheels don't spin, and the drive train makes an aweful noise like its slipping metal on metal, like grinding... and the back tires just spin out. -sorry, not trying to jack your thread, just thought with Trimble on here I might could get some help too-
  #43
Old 10-03-2009, 05:10 PM
Well...got to the source of my problem, the vacuum actuator on the front axel is bad but there was still the grinding metal problem in my transfer case. My brother-in-law and I pulled the transfer case out...broke it down and discovered that the lock-up hub assembly was cracked and half of the teeth were ground off so it would go into 4x4 until you broke traction then it wouldn't work and just sit there and grind in the T-case while your rear tires spin. Not sure which came first the T-case damage or the actuator failing but they are both related as far as timeline is concerned.
Now I just have to track down the parts, this is gonna be fun...NOT.
I'll post more when I find the parts and get it back together.
  #44
Old 10-08-2009, 10:30 AM
try the vacuum control solenoid, its cheap and an easy part to fix. its located on passenger side firewall.... put the truck up on jack stands and turn the 4wd button on, you should immediately hear it engage of disengage if you have the solenoid jumped. That is exactly what happend to my 04, problem fixed in 15 minutes! good luck
J*K*
  #45
Old 10-09-2009, 12:36 AM
4x4 says it's working but grinding in t-case and only rear wheel spin on a grade
T-case is repaired and back in, vacuum actuator (on the front axle) is replaced and she works like a dream now Boys! Thank God (and my brother-in-law, the heavy equipment mechanic). The problems were specifically...the vacuum actuator was rusted inside and would only move the shift rod about half way. Inside the transfer case a part called the "lock-up hub assembly" was cracked and the teeth were ground off (thus the grining metal noise inside the T-case) and the T-case pump was worn out (and replaced). Hope this helps others with the "4x4 system says it's working but there is a grinding noise in my transfer case and the rear wheels just spin when I'm on a grade" problem.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
