F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 06-12-2009, 04:20 PM
Vehicle: 2004 Ford F150
O yeah OP. Sounds like your actuator seal is gone. Mine had the exact same issues.
Old 06-12-2009, 05:00 PM
Vehicle: 2009 Ford F150
Not necessarily. Open doesn't mean both won't turn. It means that if one starts slipping, that is the one that will get all power. Also slipping in the front is less likely as this would also require that the rear is spinning freely too, as both diffs turn at the same rate.
Old 06-12-2009, 05:04 PM
pardon my stupidity but what is an IWE and where exactly is the solenoid located?
Old 06-12-2009, 05:21 PM
Aaron,
Look at your battery in your F150 and look against the firewall. You will see a little solenoid there that has two vaccum lines going into it. It's super easy to take off.
Old 06-12-2009, 05:35 PM
thank you trogdors4x4 and kingfish51. i did a little researchin but still confused. is the IWE and the actuator the same thing. if so that makes sense. the pop i heard came from the passenger side as did the whining sound. so did the gears strip on the actuator side, not allowing it to engage anymore. if so what all do i need to order to replace it. and is there anyway to test and make sure before i go spendin a pile of money on it? don't think the solenoid is the culperate because it was working right before the POP. unless i lost vaccuum and it slammed it out of 4x4.
Old 06-12-2009, 08:41 PM
Quote:
The IWE is the hub at the wheel that disengages and engages. The solenoid on the firewall is what sends vacuum to it to disengage. As the default is engaged (what it would be in 4x4), if there is a problem with the solenoid, the IWE will give off a grinding noise because it is engaged when in 2wd. When this happens, if not taken care of it will destroy the hubs.
Old 06-12-2009, 09:59 PM
Vehicle: 2004 FORD F150
I have a 2004 4x4 that did the same thing Took it to the dealer It was the shift rod in the t case It was a $600.00 job But i had a ford esp And it cost me $100.00
Old 06-13-2009, 12:29 PM
alright one more question. since the squeeling stopped im assuming that its shot. if so what will i need to replace at the hub? just the actuator or the whole assembly?
Old 06-13-2009, 12:57 PM
The hub is one piece. So if they are shot you will have to replace both hubs. If the solenoid failed causing the problem, then that will have to be replaced also. Or if it is bad vacuum lines, they will have to be replaced.
Old 06-15-2009, 09:46 AM
More than likely you wont need a hub. They are built stout and it would take alot to ruin that. The actuator looks like its built to give out before the hub for ease of changing and probably the cost as well. Replace your IWE solenoid on the passenger firewall and your actuator first. Trust me its very easy to do. Look in the how to forums for TN-F150's thread about changing it. I followed that and got it done in about an hour. An extra pair of hands really helps as well. If I remember correctly the solenoid from my local ford dealer was $60 and the actuator was about $130. Then to get it installed would of been $500 with parts so I saved myself some change there!
Old 06-16-2009, 12:20 PM
yea i was gettin a little confused with the actuator and hub. thank you for the input, i was trying to find this part on tasca ford but they say they don't have any. my local dealership is higher than a girraffes ass on parts so i was lookin for a place that was a little cheaper. kinda workin on a budget. thanks again for all the help.
Old 06-16-2009, 02:04 PM
glc glc is offline
Vehicle: 2003 Ford F150
Try rockauto.com.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-16-2009, 06:21 PM
anybody have the part #s by chance. couldn't find them there either.
Old 06-17-2009, 12:00 PM
Aaron you need to call your dealer or another closer to it and give them your vin and they will be able to tell you. Tell them you want part numbers they should give them to you.
Old 06-18-2009, 01:04 PM
thank you guys for all the help. btw way its for sale. the 4wd will be fixed before i sell it.
http://www.autotrader.com/fyc/vdp.js...TAFSRCHUSDTEXT
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
