F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 06-09-2009, 11:33 PM
Vehicle: 2000 Ford F150
Pinion Bearing replacement
Have had a rear end whine for a while and found out pinion bearing is sloppy (not leaking yet). I am wondering the difficulty level and special tools neaded to replace the rear pinion bearing.
2000 F-150 4x4 4.6
Thanks for the help. Barham56
Old 06-10-2009, 12:07 AM
Vehicle: 2002 Ford F150
Well, you can replace the front pinion bearing by removing the nut and removing the seal and bearing. To replace it, you need a new crush sleeve, bearing, seal, and nut. Then you need to torque the nut enough to crush the sleeve (about 400 ft. lbs. in my experience). Crushing the sleeve to get the bearing preload just right is tricky. If the diff is totally disassembled, the preload is supposed to be enough to take about 25 in. lbs. of torque to turn the pinion with nothing in the rest of the diff. In order to get rid of the whine, you may have to replace the ring and pinion gears bearings etc, the whole tomale.
Roadie
2002F150LariatFX4Supercab5.4L
Old 06-10-2009, 03:32 PM
Roadie,
Thanks for the reply. I don't particularly care about the whine it self. I just know a sloppy bearing needs to addressed asap or you wind up leaving parts on the road. Just out of curiosity though. How much might the whole tomale be at a $30/hour mechanic, and when do you know it's bad enough to require that?
Thanks again, Barham
Old 06-10-2009, 04:09 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
I would imagine its probably a 2 hour job at retail shop labor
FIDDY IS BACK HOME click pic!
J-mod
X Dynomax Bullets X 2 16" Efans X Custom Sub Box X Reverse Fogs
Old 06-10-2009, 07:59 PM
Well, there are 2 pinion bearings. Replacing the front one may be all you need and maybe not. If it needs both, you are talking disassembling the entire rear with the cost that comes with it.
Roadie
Old 06-11-2009, 04:19 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
if in doubt, do them both. aka do it right.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 07-02-2009, 12:28 AM
Pulled the drive shaft to get a better feel of the rear and and dicided that the outer pinion bearing is just part of the problem. There is pretty major movement in the pinion gear. Talked to a couple of mechanics and have decided to go with replacing the entire rear end with a used one myself. Have a torch and a pretty good bit of elbow grease.
ANy tips?:
Old 07-02-2009, 04:15 AM
1/2" drive 1/2" deep socket works well for disconnecting the ebrake cable... :P
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
