F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Powertrain
Thread Tools Display Modes
Old 05-13-2009, 08:52 PM
Vehicle: 1998 F150
well it looks like it is a lot harder to find a diff than i thought it would be. i cant find any 9.75's for a reasonable price. my next question is, can you add the factory limited slip function to an open diff? i dont think you can but its good to be positive. also, did any years other than 97 and 98 use the 9.75 or 8.8 rear with drums? thanks.
exhaust vid
Old 05-14-2009, 12:38 AM
Vehicle: 2003 Ford F-150 5.4L 4x4
you can add a LS unit, but it is going to involve tearing into the rear axle. 97-98 9.75's were the only year that used drum brakes.
Old 05-14-2009, 09:25 AM
Vehicle: 1998 F150
were there any older trucks that used either the 9.75 or the 8.8?
exhaust vid
Old 05-14-2009, 09:46 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
You have to stick with the 1997-98 model years if you want drum brakes. Have you done a search on http://car-part.com ?
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 05-14-2009, 10:47 AM
No, Ford has only been using the 9.75 since 1997.
Old 05-14-2009, 03:33 PM
Vehicle: 1998 F150
thanks. thats an awesome website jmc. and i would be willing to use an 8.8 if it was off an older truck but with that website i dont think i'll have to. thanks.
exhaust vid
Old 05-14-2009, 05:04 PM
Vehicle: 1998 F150
ok so i was looking at the link and it has a listing for the 9.75 with 3.55's for part numbers S908A, S908A1 and S908B and part numbers S909A, S909A1, S909B and S909C. what is the difference in those two listings? is there a website that has the axle codes? i found this site but i'm not sure if this is what i'm looking for? if it is then i think i found a 9.75 limited slip with 3.55's for $300
exhaust vid
Old 05-14-2009, 07:04 PM
JMC JMC is offline
When they upgrade an axle they change the production code on the tag so you can order the correct internal parts for repairs. It really doesn't matter which one you get if you pick up the complete axle with the brake drums attached.. It may be important when you order parts for repairs.
Regards
Jean Marc Chartier
Old 05-14-2009, 07:40 PM
Vehicle: 1998 F150
ok. thanks again!
Old 07-02-2009, 04:21 PM
Vehicle: 1998 F150
ok. sorry for the long delay. i havent been on the site for a while. so my dad insisted that i take it to the stealership because they said that it would only cost like $300. i told him they were lying but he didnt believe me. so i took it there and they determined that the pinion bolt had been over torqued (probably when i had it in the shop to replace the pinion seal). they said they thought we were just having it brought in to replace the pinion seal, but i think they were lying through their teeth. almost a week later and an extra $600 over the $300 they originally said it would cost. so it cost me $900 for something that could have been prevented if i had gone to a reliable shop to fix the pinion seal. so i ended up settling with my 8.8" rear end with 3.55's and LS. but im just happy to have it fixed.
exhaust vid
Old 07-02-2009, 06:05 PM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
Quote:
Originally Posted by JMC View Post
It slides off. Expect oil to drip out. I use a baggie and duct tape to seal the hole.
pffft. thats overkill. LOL
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
