Old 04-13-2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Please Help, F150 stuck in 4 Wheel Drive
http://www.f150online.com/forums/oth...eel-drive.html
ISSUE
1997 4x4 xlt 5.4 stuck in 4 wheel drive mode after not being drive for 3 days. There are many suggestions for the problem and to help overcome this issue, including:
• Disconnecting the battery, and rec-connecting again
• Possible vacuum leak
• Jacking up the wheels may allow you to shift back.
Read below for the full discussion…
Print Wikipost
please help, f150 stuck in 4 wheel drive
Old 12-28-2009, 10:05 AM
jbrew's Avatar
Originally Posted by midwest90stang
1. disconnect the battery
2. Remove motor from t-case and manually switch it back to 2WD worked for my '97 and never did the same BS again
Removing the motor is very easy then just vise grip the shaft and turn it will show you what direction
Nice ! I have to remember this one. I will now, thanks for posting
Old 12-28-2009, 03:33 PM
JMC's Avatar
JMC
JMC is offline
When the 4x4 system is bound up it sometimes stays stuck in 4x4. Jacking the front wheels off the ground releases the bind and allows you to shift back into 2Hi. The electric motor doesn't have enough torque to move the shift forks.
Old 12-28-2009, 06:06 PM
bloucks's Avatar
1992 f150, 4x4 disengaging
I have a 1992 f150 4x4 w/the 351 and push button for 4x4 engagement. Going through the snow last week, every 2-300 feet the front end sounded as if it were engaging and disengaging. Don't know if would be a selenoid or shift motor without taking it to a ford dealer. Is this something that I can repair myself?
Old 06-29-2013, 10:14 AM
Hunter Murdock's Avatar
I have the same problem the transfer case shows it is in 2 wheel drive but my rlfront axles are both locked in it shifslts to 4 low percectly and the light comes on in my cab but when I shift to four high the light doesn't Cme on I have a electric shift as well I jus replaced the CV axles hubs actuator and transfer case so any ideas on my problem? Oh and when shifted to four high the transfer case shows to in between 4high and 2h
Old 09-02-2014, 12:58 AM
Chevyfan's Avatar
Need help.
I have a 1997 Ford F-150 That is stuck in 4 low and we can not get it out for nothing. please help. It is a automatic and the switch is on the dash. I have no light saying it is on, but I know it is. Iv tried what you have said all to the point of taking the battery out and such.
Old 10-13-2014, 06:35 PM
martinek's Avatar
4x4 sticks.
I have a 1998 Expedition Eddie Bauer 4X4. I put it into 4wheel low and it went right in. When I tried to get it out, it wouldn't come out. I repeatedly played with the dash switch and it eventually came out and back into 2H.
What would cause this? I have not since put it back into 4L. I'd like to be able to use it. What could be the cause(s) for this?
Old 11-09-2014, 07:40 PM
rkd's Avatar
rkd
rkd is offline
Coincidence, I went through this for the last 2 years with my 97.
You can shift it in and out of 4wd manually by removing the shift motor and turning the shaft as noted earlier in this thread.
After 2 years and two dealers, we found the electronics good and the case binding.
A new/rebuilt tcase fixed it! Probably the reason a lot of these bind.
Old 12-15-2014, 05:06 PM
662tritonfx4's Avatar
will not disingage 4wd
I need help my 05 f150 will not come out of 4wd. I already tested the switch and also the transfer case shift motor. I can take it off and make it go back to 4wd manually.
Old 07-22-2015, 12:41 AM
Seanstruck5's Avatar
What about if you dont have the electric and have the vacuum solenoid
Old 01-31-2016, 08:46 AM
Christallee's Avatar
I am having the same problem as most are mentioning here. I have recently replaced both actuators and solenoid and still having trouble! Had the truck out yesterday and realized it was in 4x4-lights in dash were not lit to tell me so. On the way back home the truck made a horrible noise and now I am stuck in 4L, lights still not lit in dash saying what state it is in. Ive tried the neutral/brake and switch to 4H/2WD and nothing. The front drive shaft is turning telling me that the shift motor has engaged properly. We have taken the vacuum lines off at the actuator and there is a suction. Anyone have any further ideas? The lights in the dash always worked before so im puzzled as to what is happening now.
Old 02-02-2016, 10:49 AM
CBJ's Avatar
CBJ
CBJ is offline
My 97 f150 is stuck ib 4x4
Saw you mesage string and have the same problem. My 97 was first stuck in 4x4 High and would not go back to 2High. Jacked the fromt end of the truck off the ground and it did not go back to 2 high but did go down to 4x4 Low. removed the transfer motor and manullay switched the transmition to 2 high but could not rotate the transfer motor to 2 high position. Unpluged the motor wiring harnes and still could not rotated the tranfer motor. The dash still indicated the truck is in 4x4 Low even with the switch in 2 High. Should i be able to rotate the transfer motor with a screwdriver in the slot if it is good or is it seized and no good? If the dash still indicated 4x4 Low does this mean that the dash indicator is controled by the position of the transfer motor?
Thanks for you help on the form and i hope that you can give me more information.
CBJ
Old 02-02-2016, 02:20 PM
FordServiceCA's Avatar
Ford Customer Service
Hey Christallee,
Have you had a chance to have this diagnosed by your Ford Dealer? What's the model year and current odometer reading on your F-150?
Nick
Old 07-15-2020, 01:36 PM
riderboy1961's Avatar
You wrote: Remove motor from t-case and manually switch it back to 2WD worked for my '97 and never did the same BS again.
I dont quite understand...
Question: Were you able to switch into and out of 4x4 without problems anymore?
Or did you never put it in 4 wheel drive mode again?
Old 07-15-2020, 01:40 PM
Did you ever figure out what was wrong?
What was the fix?
Thank you Sir
Old 11-04-2021, 03:06 AM
bevid9's Avatar
I have a 2000 GMC JIMMY it has a push button 4 wheel drive, The vehicle treat light is on and I'm stuck in 4 wheels high, Is there any simple way I can get this back into 2 High until I get the problem fixed?????
Quick Reply: please help, f150 stuck in 4 wheel drive
