Converting 97-03 F150 4WD to 5x5.5 lug pattern
I recently picked up some new wheels with a 5x5.5 bolt pattern, and I needed to figure out a way to convert my front stock 5x135mm pattern to 5x5.5 (with 4WD)- I have an full floater rear end with aftermarket hubs, so those were already converted.. It ended up being much easier than I thought it would, although it took a lot of research. No one makes an aftermarket hub that will work, as far as I know. However, the front hub assemblies are all one piece, sealed, non repairable units which are made by Timkin. As i found out, Timkin also makes very similar units for many applications (a couple of hundred), which can be found here: http://www.timken.com/EN-US/products.../Catalogs.aspx . I downloaded their catalog, and found out that the hub assembly from a 2000-2001 Dodge 1500 (Timken part # HA599863) has the exact same measurements, axle spline size, etc, but has the correct bolt pattern. I picked one up and it bolts right on. It is also available with or without ABS, so you can get rid of the ABS module, which is integrated into the assembly, if you choose to. I just needed to press out the studs and drill it out for 5/8" studs. You do need to run the Dodge rotors, which are slightly larger than the Fords, and re-mount the calipers. But, it is a pretty cheap way to convert a 97-03 Ford 4WD to a much more common lug pattern.
If anyone needs any more info, let me know.
Opps- fixed the link.
I bolted the new hub assembly up last night, and everything fit perfectly. I have some rotors on order, so I will see if I have to re-mount the stock calipers, or go with aftermarket calipers. The stock F150 rotors are 12.13" in diameter, and 1.02" thick. The Dodge rotors are 12.10" in diameter, but 1.18" thick. The diameter is close enough, but the offset may be a little different. I will post up here when I get the rotors and figure it out.
Good Guess.....they were around 63.75 a piece.
Ya they are about 1.25" thick so they stick out that much farther.
I've got plenty of pics in my gallery. There's alink in my sig if your interested.
It's a mud slinger thats forsure.
Yep- The big issue is going to be whether or not the calipers will need to be relocated. I have aftermarket spindles up front, so it is not a big deal to remount the calipers, but I wouldn't want to do that on the stock spindle (it is cast, I think??). I should know next week when my new rotors arrive. I will update this thread when I find out.
Updated info
I picked up a couple of rotors today to check for fitment. The 2000-2004 Dodge 1500 rotors (which are 12") have a huge offset towards the spindle- approx 2" (the stock F150 rotor offset is only about 1"). It doesn't quite rub on the spindle, but it is close, and there is no way to use the stock caliper location. I looked at some 2005-newer rotors (which are bigger at 13") and the offset is only 1.5" offset. You still wouldn't be able to use the stock caliper mounts, but there is plenty of clearance between the rotor and the spindle- plus, they are larger diameter.
So, as far as I have been able to find out, you will have to re-mount your brake calipers to switch bolt patterns
However, it will also allow you to go up to a 13" rotor.
Sorry for reviving an old thread, but I ran across this on google and have a few questions....Ok, so i've been trying to find another(cheaper) rear diff as they only made the one for these trucks for 6 yrs and are hard as **** to find, the closest thing ive found to work in my truck was a 9.75 which would be great but the guy wants 450 for it drum to drum. My stock 8.8 is toast, needs new diff, all new bearings, new ring and pinion, everything. I could probably get a 9" for next to nothing or an older model 8.8 a helluva alot cheaper. But back on topic, what would keep someone from just redrilling the bolt pattern on the stock f150 rotor, and if need be have the center bored out slightly????
