05 FX4 4x4
05 FX4 4x4
Hello all,
I am a new person to this site and I have found a lot of useful information here but have yet to find a solution to my problems.
My problem is that when I shift the in dash **** to 4hi or low, i get no grip from the front. The 4hi and 4lo lights in the dash all light up when in the respective position. I have checked the vacuum lines and they are operating properly. I even jacked up the front driverside tire and put it in 4hi and noticed that the tire spinned when i turned it by hand as well as the axle shaft going into the hub assembly. I then put it in 2hi and the shaft would not spin with the tire...so that leads me to belive that at least my vacuum lines are working and ingaging/disengaging the hub. I then went as far as putting a floor jack under the rear diff and raising the rear wheels off the ground, then i put it in 4hi in drive and tried to pull forward a bit to see if the front tires would pull forward...but nothing happened.
I can hear the clunking sound from the transfer case when switching from 2hi to 4hi and 4low...
Does anybody have any suggestions on this one??
