Limited slip axle not limiting slip
Try changing the fluid but don't put in the full amount of friction modifier. It will burn up the clutches quicker, but it may be worth it if you really want the results. I'd start with half and go from there.
BTW, I've heard of the clutches going bad after less than 70k miles, so you may be getting there.
ECGS: when you say "shim them up", do you mean put more preload on the carrier bearings? Isn't that bad?
