Vibration/ click into 4WD Vibration goes away
Have you checked the vacuum connections on the tops of your hubs? Mine did this awhile back and it ended up being that one of them came off and that one hub was locked, causing it to vibrate like crazy. After plugging it back in al of the vibration went away. It is a 2 in 1 hose that is ran to the top of the hub, which is behind the brake in plain sight.
