NEWB NEEDS HELP plz...9" rear end?
Hey guys id first like to say its great to be part of the f150 forum. i have a 2001 SCrew prerunner. It has the 4.6 and the rear end gave out the other day. It is a brand new rear end but they screwed up building it. My question is how much work is it to swap it to a ford 9"? I have a 9" in the garage and was wanting to maybe just swap it into it. I have hookups through work for any parts. Any help would be greatly appreciated.
Thx BRADKASH
Thx BRADKASH
As for ABS, there are things that can be done. Its the braking system that needs abs, not the axles or ring and pinion, so it is fairly easy. Currie offers a 9" swap. Has everything on it. I am sure you could place the order for a direct swap. This one I foudn today, did the currie 9" swap
http://flickr.com/photos/darrius/set...7604491380604/
You will most likely need a custom driveshaft. One thats made for the 9", but will still work with your application. You will need to shave down the rear end, and weld in new spring perches to the width of our trucks. You will need to most likely make/have made custom leaf perches. After that, weld on some custom shock mounts, and get all the plumbing done up, you should be good to go. Rear end swaps are really not all that hard or involved.
yea i agree mercedes... i actually had the 9" for a v8 s10 i had but i sold it so i figured i might as well use the rear end. and i want it wider then stock because i have the huge flared fenders. as for the drive line and perches.... i know the guy that owns the local driveline and rear end shop so im not too worried about it. i think i might just slowly work on the 9" and swap it out. as far as the abs... my front abs sensor is broken so as of right now i dont even have abs. thanks for the info mercedestech
No problem bud. Just like seeing different one off things. On this site, for some reason, there are a lot of haters of fabricating. Everyone bashes someone who wants to do a SAS and says just buy a SD. They just don't get it.
Anyways, like I said, 9" = beef. Build it up right. If your not in a hurry, spend the time and money to go chromo inside. Get a good solid diff and be set. If your buddy owns or works at a rear end shop, I am sure he can help ya with the abs system. As for abs, I hate it anyways ! overrated.
And when it comes to building...it rocks! No manufacture would build a truck that has all of the parts that you may want. You may want a front axle from a ford, then a rear from a gm, then a custom x-fer case, oh yeah lets bolt up this different tranny since it has a better 1st gear etc etc etc etc.
Also gives you a reason to spend the weekend in the garage when the wife is being a pain LOL
^^ amen brother. I have seen some beef 9" rollin around on the trails. Handlin some 39.5" meats with ease. Doesn't the Spider 9 axle use the 9" ?? Best axles on the market IMO.
Like you said, building your own, and mixing and matching to create your OWN creation, well, thats the end all be all IMO. Nothin better then getting a comliment on something YOU built, or out performing your buddies bought rigs, with somethin ya built.
Speakin of 1st gear, you see the new F150 trans comes with a 4something:1 1st gear ??
Lastly, go get the new Haulin or Crawlin 5 dvd. Just got mine, its BAD !!!
What kind of 9" did you get? There are many types from cars, trucks etc which have different lengths, spline counts, and overall strength. I will be running (in the explorer now) a 78 big bearing 31 spline 9" from a full size bronco. The early broncos's have 28 spline axles, etc. There are different center sections, N (nodular), CAW, WAR, etc. That's all kind of moot if you want to build it up.
Good info:
http://www.kevinstang.com/Ninecase.htm
From what i've discovered while building mine...mainly brakes. Mine is pretty stock, not going to upgrade the stock shafts till I pop them
Disk Brake conversion:
explorer disk brakes, also the curie disk brake setup.
I've done alot of reasearch and have yet to find a 9" which this will actually bolt onto without mods. Search around and you'll people who say if you have a big bearing 9" this will bolt on. Well...I have a big bearing 9" and there's no way in hell it'll fit stock. Not saying that there's not a 9" out there where this won't bolt up to but i've not found it.
Custom brackets and GM calipers. This is by far the easiest conversion. About the only problem is that the parking brake is built into the caliper...not as reliable as an internal brake setup but still works. I'm running oldsmobile bravada calipers...no parking brakes at all, i'll be using line locks but I won't be using them as traditional parking brakes.
I have a set of d70 outers sitting on the shelf for a possible full floating conversion in the future...would be pretty cool and nice stronger. Also would like to do a truss sometime as well.
Good info:
