Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Other Powertrain
Thread Tools Display Modes
Old 09-15-2008, 01:44 AM
Conversion from no hubs to manual hubs?
I have a 97 F150 Supercab 4x4 w/4.6
It has the shift on the floor system with no hubs, manual or auto.
Is there a conversion kit to make this into a manual hub system. I think eliminating the front axles and R&P turning all the time could make a big difference in MPG and power etc. Is there such a kit available?
Thanks...Rustypig
Old 10-02-2008, 01:34 AM
Question Bump...must assume...
Well, I suppose that from the number of views, and no posts, that there is no way to convert this 97 F150 to a manual or auto hubs system. I've been debating on selling it and going to a 5.4 or back to a Chev. The 4.6 just doesn't seem to have the ummph to warrant driving the smaller v-8 with the poor mileage it gets. I'd like to keep her, but it's already got a K&N, with dual after market exhaust, and feels like it could barely pull a sick hooker off a bar stool, especially at highway speeds in 5th gear (always shifting down). Its only got 115K and has been maintained fairly meticulously so if I'm missing something let me know.
Old 10-02-2008, 02:23 AM
Vehicle: 1997 Ford F150
never seen this thread, but i have never found a hub conversion for the 97-03 models. as far as the IFS systems go im not aware of one that has a selectable / disengagement hub
6" fabtech w/ 7" alcan high arc leafs, 4.88 gears with detroit locker, 315/75/16 nitto terra's.
Packin built and blueprinted Lightning powerplant with p&p heads under the hood, backed by a race built 4r70w. what chu got?
[IMG]>>Offensive smiley removed<<[/IMG]Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. Rod has screwed with me on a bad transmission build. saga here
Old 10-02-2008, 10:54 AM
Vehicle: 97 F150 4x4
Hmm...I never noticed this one either. Strange, I just replied to the same (I think) question for another guy up in the tranny forum this morning too.
I'm not aware of any manual hub conversions for the 97-03 IFS Fords either.
The ring-n-pinion shouldn't be turning if your front axle is unlocking properly...just the half-shafts and the spider gears inside the gear carrier. This won't make that much difference in power/mileage if you could trim that out of the equation.
Fill your axles with a good synthetic gear lube and call it good.
How is your truck geared and what size tires do you run? Most 4.6s that I've seen have pretty tall gears for the tires they're running...if you regear lower, you'll see more bottom end torque applied to the road.
You could always SAS the truck too. Then you could run your choice of axle and lockout.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
