Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Other Powertrain
Thread Tools Display Modes
Old 09-07-2008, 10:41 PM
Vehicle: 2002 Ford F150
rear diff
ive got a 2002 f150 4.6 2wd and shes got about 128,000 miles on her, and i pulled the diff plug the other day and WHOA it was black and really low.
i was thinkin about pullin the cover off and cleaning it all out, im sure theres a bunch of shavings in there, and cleaning out all the burnt gear oil out of there since theres no drain plug on it, then sealing it up again and puttin it back on and putting royal purple gear oil in there,
is this gonna be to much trouble, should i just use our little vaccum (i work at a quick lube) and then put the royal purple in there and risk it mixing with the burnt oil? or will i be better off takin it apart and givin her a good cleanin
btw its the 3.55 open rear end
[IMG]Please re-size sig image to 500x100[/IMG]
Signature Thanks To DarrenWS6
True Dual 10 Series Flowmaster, H Pipe, Maggie Hi Flows (94106) http://www.youtube.com/watch?v=nezTBIV8bOA
Old 09-08-2008, 01:00 AM
Vehicle: 2003 Ford F-150 5.4L 4x4
dude, this isn't that hard, trust me. the hardest part is prying the cover off, and that isn't even that bad. just unbolt it, take a scraper (I used metal) and carefully pry around to break the oem gasket sealant loose. don't use a screwdriver, pry blade, you'll risk gouging the cover. once you have the cover off, drain all the oil, and reach in w/ a rag and clean under/around the gears.
clean the cover mating surface/and the diff housing very meticulously of all gasket remnants. you want to be as thorough as possible here in order for the cover to seal properly. apply blue permatex, or a gasket and sealant and close the cover back up and bolt it down. unplug the plug, and clean it. use a transfer pump to siphon fluid in the plug hole. i'm not sure on the ford spec for the 8.8, look it up. ford specifies fully synthetic fluid ONLY. you don't need the friction modifier in an open diff. this isn't that hard, do it properly and drain/clean the rear pumpkin.
Old 09-08-2008, 09:15 AM
alright man thanks for the help!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
