Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain (OEM) > Other Powertrain
Thread Tools Display Modes
Old 08-28-2008, 05:32 PM
Speedo Correction
Hello, I'm New to the forum and have my first question.
I have a 99 4X4 w/ 3" body lift and 35" BF's AT's. This larger tire diameter is trowing off my speedometer and odometer.
Can I simply change some setting int the computer to compensate, or do I need to change gears?
Any pros/cons for either? Thanks.
Old 08-28-2008, 05:56 PM
Vehicle: 2004 FORD F150
you should change gears, but that wont help the speedo/odometer. Gears will help put you back into the proper powerband, allow your transmission to operate normally and last longer.
You need a tuner for recalibration. They can re-set your computer to tell it what tire size you have. You can find these tuners online. Some dealerships can do this as well, but not all. I think your model also needs a speedo gear swap.
oh, and welcome to the site !!
(thanks Chris)
Old 08-29-2008, 09:59 AM
Are the tires the reason the shift from first gear is real stiff? If I keep my foot out of it, it's not so bad. All other gears appear to shift fine.
Are changing gears difficult for both trans and spedo? Where would one look for recommendations on what to buy?
Thanks again.
Old 08-29-2008, 03:53 PM
Will 4.56 gears help ease the wear on my trans? Any installation notes?
I see the sticky at the top now!!!!!!
Old 09-01-2008, 02:16 AM
Vehicle: 1997 Ford F150
If your odometer is digital and not the old analog gauge then you can recalibrate the speedo with a programmer.Not sure if any of the early 99's had analog gauges, Ford made the switch to digital with the 99+ but there may be a chance that they put the older 97-98 style gauges in the early 99s to use up their inventory of them.
97 XL 4.2L V6 Reg Cab Std Box 4r70w 3.08 Non LS, Firestone Destination A/T 255/70R16s, Line-x spray-in bedliner, Truxedo Deuce tonneau, 20% tint, AF1 CAI, ASP UDP, Cherry Bomb Vortex catback SIDO, Magnaflow Hiflow Cats, Troyer tuned.
Whaddya mean I don't pay my bills??
Whyddya think I'm broke!!
173.8 rwhp 226.7 rwtq
Old 09-02-2008, 08:23 AM
It's digital.
Anyone in the Hampton/Newport News VA area have a programmer that could help me out?
Old 09-02-2008, 04:01 PM
Vehicle: 200? FORD
4.56 will help your trans survive and also help your mileage and power come back and they may even help correct your speedo (at least bring it closer)
even a cheap canned tuner will help correct your speedo, once your speedo is corrected your shift points will be back to stock
thanks to Dirty88 for the sig
- '01 Procharged Lariat on a custom suspension - Tuned by Troyer
- '03 Harley Davidson Edition - still stock and staying that way
- New Eddie Bauer Expedition - Tuned by VMP
old albums -http://www.f150online.com/galleries/....cfm?gnum=8805
new albums -http://www.f150online.com/forums/mem...me-albums.html
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
