Diff fluid change
Diff fluid change
Just changed the diff fluid (front and rear) on my 01 Screw. I figured after 120,000 miles or so it couldn't hurt. Planning on doing the same to the expedition (75k on the clock) and changing the fluid in both transfer cases. The owners manual sates that the diffs are considered lubed for life. Has anyone noticed any benefit to changing the fluid? Better fuel economy? Anything?
Also I thought it odd that the 04 Expedition calls for 75W-90 in both front and rear diffs, but my 01 is 75W-90 and 75W-140 respectively.
on
1 Post
I think the consensus here is that the Royal Purple is the only stuff you do not have to add the friction modifier to as it seems to have enough in it already. Every other brand, I believe (someone let me know if that is not the case), you should add a 4 ounce bottle. You can get it from Ford.
With open diff you do not need friction modifier. With the diff fluid change you will probably not see any noticable difference (fuel milage) but it is good preventative maintenance.
These trucks came into the marketplace with different specs & configurations. Consult your owners manual & maintenance schedule. You will need friction modifier if you have limited slip.
