pulling someone out
For light pulls using reverse is fine but for anything serious always pull going forward.
The reverse gear is not a lower gear ratio, you have the mechanical advantage pulling forward. The weight will shift to the side you are pulling from and a solid rear axle will deal with the power of 4low much better than the CV's can take the strain.
The tailgate will also deal with a broken strap much better than the grill will, I say this from experience.
Use a D ring that attaches to your rear hitch. Use a tow strap rated for atleast 20k and use the lowest gearing possible. Go straight into 4low as it will give you better throttle control and place less stress on the torque converter. Never use a chain because if they do break they will cause large amounts of damage and can harm people. Place a wet towel over the strap to absorb the energy if it does break and to keep it from damaging your truck.
Pull the rope taught then have the stuck person spin the tires slowly while you give your truck more and more throttle. You only want to use enough power to get them out. If you cant get traction you may have to "******" the person. Usually giving the strap just enough slack to touch the ground then lightly bumping a stuck vehicle will be enough to move it a bit then you can get back into the throttle to keep the momentum.
I have recovered hundreds of trucks and I have learned use just enough power to get the job done as too much breaks straps, bends hooks and just tears up both vehicles
You definitly get better traction pulling from the rear. Think about it, the motor in the front and little weight in the rear.....The pulling actually settling more weight in the rear give four better balanced tires the chance to grab.
4 low is also a wise to save strain on parts before the transfercase, like your engine and tranny. Also if your truck starts to hop, back off of the gas pedal, as the hops are good for breaking the driveshafts and axles if left go for too long. The tow hooks are good for getting pulled out, but no so good for doing the pulling.
