Passenger side front 4x4 axle tube
on
The diff is stock. The vacuum motor is history.
http://www.4x4posi-lok.com/app_ford.html
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
on
Update
I got a used part from a triple P operation. Pick, pull and pay. $42.00 out the door. I had to bend the shift lever on the donor axle to get the axle tube off. The Vacuum motor was stuck. Once home I spent an hour getting the vacuum motor out of the fitting. I had to cut it and drill it out. I put some spark plug anti-seize in the hole and all I need to do is install it and adjust the posi-lok cable.
Regards
Jean Marc Chartier
PS. It has been either too hot or raining to work on the truck.
Regards
Jean Marc Chartier
