Rear end noise when pulling hard
Just recently I've had a "grinding" noise coming from the rear of my '02 F-150 SuperCrew KR. It happened the first time when I was stopped on a very steep incline and then started up. It sounded like maybe the limited slip differential was slipping - the engine ran up some RPM's, noise from the rear, no movement. A little more gas, and it moved and drove OK. Now, every now and again, starting from a stop making a right turn (or left?) I get the same sensation/noise from the rear end. I'm guessing something in the diff? OK, here's what worries me - I took it to Jiffy-Lube 10000 miles ago and they recommended changing the diff fluid. I asked if they had the right stuff for a limited slip diff, and they said yes. So, I don't know if it's a fluid issue or mechanical. I don't see many writeups about limited slip differential problems, so I suspect this isn't a common problem. Have other had any problems like this? (My truck has not been off-road, is a 4x2, has 82000 miles and has not done towing.)
Duane in Austin, TX
Duane in Austin, TX
Thanks for the tip - the receipt says "GL5 Syn 75/140 Pail", but no mention of any friction additive. It goes to the dealer on Monday, so I'll take this along. If that fixes it, I'll be revisiting Jiffy-Lube for a refund and to tell them it was my last visit. (Ford will do my oil change for $11.95, but JL is a lot closer.
Duane
Duane
Not in Ford manual
I tried two things today. First I consulted the manual on the truck. No "friction modifier" is mentioned, just 74W150 synthetic fluid. Second, I stopped at Jiffy-Lube and they confirmed that they only put fluid in - if there is any special additive other than the fluid, they have no record of it, and they say they are following manufacturers specs. Tomorrow Ford - what makes me think I don't want to spend $$ for a diagnostic fee that isn't going to tell me anything? I guess as long as it keeps moving and an axle doesn't fall off, I'm ok!
Ford limited slip differentials require a 4 ounce bottle of friction modifier.
Controlled Slip Differential, Rear .....GL-5*[3][4]
All Temps......75W-140
3. Synthetic oil is required.
4. CS IDENTIFICATION: Letter & number on plate on door lock
pillar. (Models W/ Traction-Lok Rear Axle Add 4 oz of
friction modifier part no. C8AZ-19B546A (EST-M2C118-A)
