driveshaft replaced
driveshaft replaced
My truck is in the shop right now. My u-joints needed to be replaced but they told me that the 04 f150's u-joints cannot be serviced but you have to replace the whole driveshaft. Just letting yall know that if your u-joints go bad then plan on getting a whole new driveshaft.
I plan on replacing my U-Joints on my truck at 75k. Why?
It's a stick, and there is more wear and tear from shifting. Also I learned the hard way if you leave the driveshaft on there for a long time and then wait for the U-Joints to give... it will be a true headache to remove the driveshaft. Learned the hard way.
I was told with automatics, they tend to last to about 100k. But with sticks, depending on the driving habits, they will tend to last to about 75k.
Plus I prefer the Zerk-fittings.
I think the sealed ones lose their lube after 50k anyhow. Not sure, but I don't like them.
But yes, they use the stupid stakes on the NBS models.
I think the '97 - '00 use the Jesus clips. I could be wrong. IIRC, it could be '97 to '05. But it sure is mystifying from looking around.
But IIRC I did a search a couple months ago in various stores while looking for U-Joints on my Dak, and I happened to ask them what years, and I got weird answers. I even did a few searches, and came back totally lost.
Personally... if you want my opinion, the best way to be sure if to go under the truck and look. If it has Jesus clips you are usually good, UNLESS you can't get them out, and you will wind up having to bring that driveshaft to a mechanic to have them cut it off with a torch. I had this happen on my Dak, but luckily I had torch.
Also, I prefer going with Spicer Heavy Duty Cardon Joints for you propeller shaft. I've heard nothing but excellent reviews. They are the same ones used in commerical applications such as school buses, tractors, etc.
