Speedo correction w/ring & pinion change
One option, use a tuner and adjust. I have an XCAL2 tuned by Troyer. Just swapped 3.73 for 4.56. Speedo was way off, I reflashed to stock, then on an XCAL2, you can enter opt parms and change the pre programmed gear ratio. It was about a 90 second 'fix'.
