IWE Solenoid
IWE Solenoid
Went to my dealership today for a oil change. Service writer came to me and stated they had a vehicle in the other day that had a faulty iwe solenoid. Said the owner in the end had to have hubs replaced along with the solenoid. Recommended that I should have the updated solenoid put in and also have the Transfer Case Flushed to make sure this doesn't happen to me.
I told him I've never had any problems the truck and I would think about his suggestions. After reading up on the problem I can see having the solenoid replaced but unsure of the Transfer Case. Should I also have the transfer case flushed with only 41000 miles on my truck. Is the solenoid replacement a easy do it yourself for a novice. Thank-You, Troy
I have been following the IWE problem on this forum for a while, mainly because my truck is one of the victims. From all of the posts i have read on here i can't see why the solenoid problem would affect your transfer case. It never hurts to change oil more often than necessary, but i don't think it IS necessary.
