f150 7700 series
#61
Trans temp will also depend on tire size and gearing and driving situation. Bigger tires with the same gearing = hotter (and vice versa) and city driving = hotter. My 8200 GVW (4R75W) truck runs 160-180F in city driving on normal summer days read from the valve body sensor. I have a deep pan an inline trans filter, which add a little to the cooling
Depending on where you are taking the readings, 180-200F is not overly high in and of itself, but you would wonder what it's going to be under a load. Continuous temps to 225 isn't too big a deal but over that is worrisome long term. The trans is really quite fine up to 250F continuous but the oil is oxidizing very quickly. If you change it more often, even that isn't a big problem. In the long run it's the amount of time at high temps that kills the oil. The converter temps (I can read converter out temp separately) can spike well over 250 at times when I'm working the truck hard, but the oil doesn't stay that hot long once the converter locks up.
I Have a Mag-Hytec pan, which holds 4 more quarts than normal. It knocked about 10-15F off the temp
#62
Where did you install the sender? Cooler lines? Pan? Screwed into the case? Or are you reading it from a programmer or OBDII interface (UltraGauge or ScanGaugeII). They will all read a slightly different temp because they are sampling the oil at a different spot in the tranny. If you are reading the converter oil temp (cooler "out" line from trans) 180-200 is pretty good. Pan oil temp would be about 150, which runs 30-50 degrees cooler than the converter generally. Unless you are pulling or carrying a load, in which case converter temp may spike lots higher
#64
#65
#66
#67
#70
#73
#74
#75
