O2 sensor on 06 explorer
Old 10-04-2014, 08:03 PM
migdaddy's Avatar
CEL came on and showed P2195 o2 sensor upstream running lean. Ive also noticed that when the truck is cold, there is a pretty noticeable whistling sound coming from the engine bay. Could there be a leak somewhere that is also throwing off this code? Taking it to my mechanic on Tuesday but would love others opinions as well. Thanks.
Old 10-05-2014, 01:39 AM
jgger's Avatar
The sensor is reporting the problem, leave it alone. Track down the whistle and you probably have solved the issue. Could be as bad as a cracked intake or as easy as a bad hose.
Old 10-13-2014, 09:50 AM
migdaddy's Avatar
ending up being the o2 sensor. Wasnt moving at all. replaced that. checked all hoses and lines. EVerything is good. Whistling sound is probably just a noisy intake. I remember my F150 had a K&N intake that made a pretty noticeable whistling.
Quick Reply: O2 sensor on 06 explorer
