Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Other Models
Thread Tools Display Modes
Old 01-04-2007, 06:22 PM
Coolant Leak From Throttle Body
Have a 1995, F150, V8, 5.0, 4x4, Automatic, XLT, w/ 289K miles. Have coolant leak from the Throttle Body. Coolant hose goes in bottom of throttle body and out top. In between is what looks like a port that may have been plugged or a line to something. Investigation has not led to any other location for coolant to go to. It is no longer plugged and is venting/leaking coolant. Believe it may have been plugged and corroded away. Dealer stated same but had no recommendation rather than replace the throttle body, $512.00. Any suggestions as to how to close the port are welcome, any kits out there? Right now I have bypassed the throttle body to avoid venting coolant but this is just temporary. Thanks!
Old 01-06-2007, 11:11 PM
Vehicle: 1997 Ford F-150-4.6
coolant leak
Have you ever heard of J.B. weld this may be the trick you are looking for it is a two part epoxy you mix and then it hardens like steel. Hope this helps
Old 01-10-2007, 04:51 PM
Vehicle: 2001 ford 250
hit the junkyards f 150s are everywhere. pick up a throttle body, give it a good cleaning and you should be good to go. or you can go to a hardware store and pick up an marine plug basicaly a rubber plug with a bolt you tighten and the plug expands. i used one on a old chevy when i stripped the oil drain plug.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
