Towing mirrors revisited...
So I found a pair of towing mirrors on C/L for a good price for my 04 XL150 work truck. Buying them tomm. Downloaded installation PDF and apparently there's a special tool needed to remove the window cranks so you can remove the door panels? Anyone have any idea what this tool is or if there is a reasonable facsimile [improper use of a tool] to accomplish this? Seems easy enough but I'm clueless how to remove the window cranks. No visible allen bolts or screws. Thanks in advance.
Two bolts at the bottom of door, two bolts behind the door handle cover, remove speaker grille, unbolt speaker and unplug. Door panels comes off by pulling out and up. There are many clips. Mirrors are secured with 3 bolts.
I've taken my door panels off way too many times and swapped mirrors 3 times so far. It's easy.
If you have any more questions, ask and I can add photos on how to do it.
If you have manual windows, it's just a T-15 torx bit. First pry up the window crank cover and then remove the crank with the t15.
