F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Other Body
Thread Tools Display Modes
Old 10-27-2009, 01:02 AM
Vehicle: 2004 ford f150
fixing rusted bed
hey guys, ive looked around and couldnt really find a definite answer to my problem. my bed has always rattled over bumps which on the street isnt bad. problem is during hunting season i regularly drive on dirt roads, which makes the squeaking unbearable to the point where i cant use it. i took it into the dealership because i found a bed bolt that was loose and sliding around. so i tell them to tighten it along with some other regular things i needed done. They told me that the noise came from the bolt which was as tight as it would go, but the area around the bolt had rusted allowing it to slip. the bed hasnt rusted through, just the top layer. what can i do to fix this?
Old 10-27-2009, 02:57 AM
Vehicle: 1998 Ford F150 4x4 5.4L
Chuck the bolt, replace w/one that will work. AFTER you wire wheel or grind every bit of that rust out of there. Use "Etching Primer" on the bare metal, 4-6 coats. Dupi-color sells it in spray can form, but make absolutely sure it says "Etching" Primer or the fix will be short lived. - Then paint. You might want to wait a couple weeks before running a bolt thru it, takes awhile for everything to cure/harden real well,- grease the washer first
Old 10-27-2009, 09:06 PM
alright thanks ill get on that. Do you think instead of using the primer on it after i grind away the rust it'd be alright to just have a bed liner sprayed in? I need one anyway and if its not necessary to paint and primer it after i put one in then it'll just save me time and money.
[quote]As for cookies, I am out of the White Chocolate Macadamia and M&M cookies… but I can send you a Chocolate Chip or Peanut Butter cookie if you like.
Take care.
Bill/QUOTE]
Old 10-28-2009, 12:10 AM
I would still primer it first. Once down to bare metal, I've seen it rust right back up thru undercoating. The primer is like 5 bucks.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
