Well, I just took mine to a glass place and they said that they see that alot. I stayed there and watched them take it out. You need to take the plastic rivits off and then the 2 up on the head liner. You should be able to get to the nuts. You will only take out the ones for the glass and not the plastic peice. Be carefull when taking out the glass, ( they wouldn't replace under warr. if they broke it). Once you have it out then take the glass out and then get the new sealer for the window you should be able to find it at a auto paint and body supply place. Next, just put it back in. Mine leaked in the same spot just right behind the driver side.
