My 2007 SuperCrew XLT does not have a factory tow pkg.
I am looking to replace the rear bumper because I put a crease in it. When I searched new ones, they list a different part number with and without factory tow.
Does anyone know the actual difference?
I have found a couple of used ones that came off trucks with a tow pkg. They are 30 to 50 miles away. I would like to know if they will work before I spend the gas.
Thanks for any help.
2007 F150 XLT SuperCrew
2WD/4.6L/Auto/3.55
Gold w/Beige Interior
Tinted Glass All Around
Pendaliner Bedliner
Michelin Rubber
Previous Ride was a 1998 F150 XLT SuperCab
Red with Silver Trim
On my 2nd F150 and loving it!
I have an '07 4WD/4.6L with the tow package, and the only difference in the rear bumpers is that the tow package bumper has mounting sockets for the package. It will fit your truck, and if you ever wanted to update for towing you will be ready...
I bought a bumper without the tow package and replaced the tow package parts from my original bumper with the non tow parts from the other bumper. Same hole patterns, bolted right up. Worked fine.
If the tow package bumper you're thinking of getting comes with the bumper to frame tow package brackets and all the nuts and bolts it should work.
__________________ Lifechurch.tv Mods:Edge w/PHP tunes, Roush OR exhaust, K/N, Roush valance, Harley heads and tails, black fogs, FX2 upper and lower, GF9949, Eibach dampers, Snuglid, Bedrug, 22" Yoko's on black Boss 313's, Saleen sub, stub antenna. Mods to paint:Reflexxions hood, 3DCarbon skirt kit, Street Scene mirrors and cowl. Flat Rate Tech - Click on Episode #22 for info on 5.4 VCT Theory & Operation.Screen-FX
The trucks that came with the tow package , Those bumpers will only work if you have the tow package on yours or you would have to order new brackets
Thanks for the info.
I have already installed a receiver hitch on my F150. The U-Haul hitch simply bolts to the frame. No attachment to the bumper is necessary. This eliminates the need to change the bumper brackets.
2WD/4.6L/Auto/3.55
Pendaliner Bedliner
Michelin Rubber
