Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Body > Other Body
Thread Tools Display Modes
Old 07-27-2008, 11:33 PM
Rocker panel / bottom of door coatings...?
So after watching these forums for a while I've decided to finally start building up my truck a little. I've ordered 35" nitto terra grappler a/ts and a 3 inch body lift. But I've got a problem with rust underneath the driver side and passenger side doors...its starting to round the corner and crawl up the door now. My truck is black. I've sanded all my problem spots down, sprayed on a primer and then rustoleum black. Ive decided that I dont like the way it came out...noone else would really ever notice but I do and its annoying. Ive seen other vehicles with a strip along the bottom of their doors..some make this strip with a roll on bedliner. I think it would come out ok if i did a 8 inch strip along the bottom of the truck. Now my question is what to use? herculiner, another type of roll on bed liner, or somthing like undercoating? The roll on bedliners seem to come out good but many complain about chipping like a year later. Has anyone had any experiance with this situation? I'm looking for somthing affordable so lining it with rhino lining or somthing like that is kinda outta the question.
Old 08-08-2008, 06:27 PM
Vehicle: 97 F150 4x4
Herculiner will work fine. I know a couple guys that have used the Dupli-Color brand roll on stuff too, but they've only been done a few months so I'm not sure how well that brand holds up. I used herculiner for chipguard on my Nissan and it's holding up pretty good after a couple years...this is with daily driving on gravel roads with A/Ts chucking gravel stones constantly.
The trick to getting it to stick and not peel or chip is in the surface prep before you apply it. make sure you do a good job of dewaxing/desiliconing the paint using an acetone type cleaner (careful with this stuff it's nasty!). Next, scuff the area you're coating with fine sandpaper so the coating has something to grab too. Apply as per the can's instructions.
You might want to check with a local Rhinoliner place anyway. There's a lot less surface area than if they're doing a whole bed interior so a chip guard application should be cheaper than getting a bed done. I'd guess you could probably get it done for $150-200...compared to $70 for the DIY stuff and the labor you stick in. Might be worth looking into anyway.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150online is not affiliated with the Ford Motor Company.
