Firewall hole in 2000 single cab.
Old 01-20-2002, 01:28 AM
Formus's Avatar
I have a 2000 single cab and can't find a hole in the firewall for the life of me. Does anyone know where one is? I'm looking for one to run my amp wires and CB wire through. Thanks in advance.
Old 01-20-2002, 02:49 AM
Syeth's Avatar
I Probibly went about running mine wrong but what i did was follow the harness from the battery across the top of the firewall and then ran it through the hole that the wire for the hood pop thingy goes through. Use a coat hanger thats just how i did it.
good luck
Syeth
Old 01-20-2002, 11:06 AM
Alf's Avatar
Alf
Alf is offline
Formus,
I also have a '00. Look under your dashboard on the driver's side, find the steering column and look for a rubber plug right next to it, I think it's about an inch in diameter. I ran two cables from the battery to power my amps.
Hope this helps.
Alf
Old 01-20-2002, 04:09 PM
Formus's Avatar
Thanks guys. That plug was so obvious I'm embarassed that I didn't find it earlier.
Quick Reply: Firewall hole in 2000 single cab.
