Other Dash kits?
Check this out.....
You also may want to check out these websites for different choices for installation kits.
METRA
Scosche
I used on of Metra's kits above, but I had do do some cutting in my dash to allow the radio to fit all the way to the to, actually I cut the dash out to fit all of the RCA's and other wires.
GOOD LUCK
small shelf
I called Crutchfield about a cd reciever, and i asked what accessories came in the box with this head unit(Pioneer DEH-2300), and a small shelf came with it in the kit. It is just part of the surrounding that covers the extra space up around the cd player. You may be able to order this piece seperate from the kits. I have the Crutchfield number here, it's 1-800-955-3000. Hope this helps.
Looks pretty good,
Just ordered an Alpine CDA-7878 H/U so I will need the dash Kit too.
OK I hope this dosn't sound stupid but Does the kit include everything or is there some other parts I need to get, what does the new H/U attach to? does it use screws (I assume) or what?
Could use some more guidance as I wish to get everything ahead of time for the quickest installition possable with the littlest muss and fuss...
Anyone have part numbers?
THE KIT I WAS TALKING ABOUT IS CALLED THE E-Z MOUNTING KIT. YOU CAN ORDER IT AT CRUTCHFIELD FOR ABOUT $12.00 IT JUST SNAPS INTO THE OPEN SPACE IN YOUR DASH, AND THEN YOU JUST SLIDE THE SLEEVE THAT GOES AROUND THE RECEIVER IN THERE. IF YOU LOOK IN THE HOLE THAT THE OLD RECIEVER CAME OUT OF, THERE IS A SMALL METAL LIP BACK THERE. JUST REACH IN THERE AND PRY UP ON IT SO YOU'LL HAVE SOME KIND OF SUPPORT TO HOLD THE BACK END OF THE NEW RECIEVER UP WHEN YOU PUSH IT IN FOR FINAL ASSEMBLY. AND DON'T FORGET, BEFORE YOU SLIDE THE RECIEVER IN THE SLEEVE, PRY UP THE METAL TABS ON THE SLEEVE TO HOLD THE H.U. IN PLACE SO IT DOES'NT SLIDE OUT. HOPE I HELPED YOU. IF YOU HAVE ANY QUESTIONS, JUST ASK.
ok I found the kit does it come with the sleve or do I need to order one seprately?
Oh thanks everyone for the help, I know the electronig/wiring part pretty well it is just the installition part that is new, last stero I installed was in an 70 Cuda I restored but it wasn't din. That is the new part for me.
JIm
JIm
