10-17-2001, 03:38 PM
line converters in dash
Will my two line converters fit behind the dash of my 2001 lightning? Is there room with the factory premium radio , will it cause any problems? Thanks for any info.
-Glenn
10-18-2001, 09:26 AM
I don't think it will fit behind the radio. But there is some room just to the left of the radio behind the dash that you might be able to strap them to. They also make four channel converters which are smaller than two - two channel converters. Most professionals I talked with say to keep the converter as close to the amp as possible. I don't know if it realy makes a difference.
10-18-2001, 10:07 AM
Thanks!
10-18-2001, 11:30 AM
The reason they recommend keeping the converters close to the amp is because speaker level signals are more immune to noise issues. Line or low level signals can pick up all kinds of noise in a vehicle environment. Just run good speaker wire back to the amps and put converters close to amps or use an amp with speaker level inputs and skip the converters all together.
09 Ford Flex Limited AWD
10-18-2001, 01:29 PM
Thanks for the info Norm. My situation is I've allready bought an MTX4405, and I have 2 brand new rockford fosgate stealth 3 meter RCA's. I'm so stubborn that it would kill me not to use the stuff I have. I'm a classic example of "bite off my nose, despite my face". Thanks again for the info though.
-Glenn
10-19-2001, 01:16 PM
Anytime,
Your stuff will work fine. Just keep your power wires away from your signal wires.
10-19-2001, 03:03 PM
Garage is empty, add now
Vehicle: 2001 Ford F150
Re: line converters in dash
Quote:
-Glenn
kidd2001, if the lightning dash is the same as the SCrew you have room behind and to the right of the radio under the pizza shaped insert on top of the dash. I put mine there. Be careful of the pass. airbag
2001 F-150 SuperCrew 4X4 LT – Silver w/Medium Graphite interior,
4.6 V8, 3.55 Limited Slip Axle, P265/70R17 Cooper Tires
17” 10 Spoke Aluminum Wheels, Class III Trailer Towing Pkg.,
Remote Keyless Entry, Dual Media Vistieon MP3 & 6 CD Changer,
Captain’s Chairs, Ford Cab Steps – Black, Engine Block Heater
Custom Dual Exhaust with X-Pipe, EGR Carbon Fiber Hood Shield ,Window Vent Shades, Superchip, Airaid Intake System, A.R.E. LSII Hard Tonneau cover with remote lock, Python 1500 ESP Security System w/remote start, Clear Corner Lenses, Rhino Liner, TruckVault, Infinity Kappa 50.2cs in front door, Infinity Kappa 572.1cf in rear doors, Valentine One w/Laser Radar Detector & Concealed Display, J&J Stainless Grille Insert, Pop-Lock in tailgate, 2001 Lighting Tails, Lighting Headlights, PIAA 1451 backup lights, Rockford Fosgate 400a4 & 100z2 Amps., MTX 8" Sub in Expy center console, Cobra 75WXST CB., Remote entry keypad, FactoryTech Transmission Main Control, Mag-Hytec 4R70W-DD Transmission Pan, MyFi 2Go XM radio, BellTech 3/4 drop kit, Wolo Air Horns.
10-20-2001, 02:32 AM
thanks
10-20-2001, 03:18 AM
Your basically the man, It's pretty crazy how helpful and cool everyone is on this board. My girlfriend is making fun of me right now "your never that affectionate to me, even when your this drunk" Sadly, this might be true.
15Y/O 1st car 69 dz302 camaro (12.4 with 93 pump gas +12 " MT i's for
traction, if you can call it that)
My family buisness is engine rebuilding, When I was bad as a child (4-9y/o) my father would take me into his 9 sec vega and basically scare the sh*t out of me. I love him for it now
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
