08-01-2001, 05:33 PM
how to get the factory head unit out???
i popped of the piece of dash and then tried to get the headunit out using coat hangers bent into u's to get it out. also what im trying to do is add a sub to my stock stereo. i know this is not the best but moneys tight right now. whats the best way to splice the sub in? also what color are the speaker wires that run to the rear speakers?
thx
erich
01L
08-01-2001, 05:46 PM
Save yourself the time and go to the dealer and get the release kit. They should give it to you. If your trying to use the coat hanger, once you get it in, push outward on both of them and slide the head unit out.
I replaced my in dash CD player with a Sony. Pretty easy. My factory head unit had the pre-outs for the sub. Not sure if your's does or not. Might have just been on the CD units.
My Rides->>
2004 F-250 XLT SD 4X4 SuperCab
Styleside, Short Bed, Red, 5.4L, 4.10 LS reg
2001 Ford Explorer Sport
Estate Metallic Green, 4.0L, Power Sunroof, Power Everything, Loaded
08-07-2001, 01:04 PM
Removing Factory Radio
2l8uburn, if you can't get the removal pins from the dealer, insert the "u" shaped coat hanger pieces straight in until you feel it hit a "stop"(at this point if you keep pushing the coat hanger it will probably keep going in and make it harder to get the radio out). Once you feel the hangers stop, like biggins said, push the coat hangers sideways and away from each other. The radio should then pull out.
08-07-2001, 01:29 PM
I've used the tools and coat hangers and even nails(which work really well since they don't bend so easy) and you know what? You still need to sweat it out and be patient. It helps if you can have somebody else push out on the coat hanger while you reach up there and wiggle the unit out from behind. Good luck
2003 Lightning Dark Shadow Gray
FTVB
Bedrug
JLP Shackles
K&N Drop In Filter
Infinity 10" with JL 500/1
2008 Lincoln Navigator
Ultimate with Monotone
08-09-2001, 02:16 PM
They sell the u-shaped clips specially made to remove our factory head units for abou 3 bucks anywhere you can find stereo equipment. such as wal-mart, k-mart, pepboys, autozone. I just slid them in until they locked in place and pulled out the stereo pretty easily.
Black 2000 Supercab Flareside XLT
Exterior: Ford Bug Shield, sprayed in bed liner, Billet grill, clear corners
Interior: Pioneer Premier DEH730 head unit, 2 Rockford Fosgate HEII punch 10"s, Kenwood 600 2 channel amp, Custom box.
Performance: Flowmaster Catback exhaust, ASP Power Pulleys, Airaid air intake,
08-12-2001, 10:24 AM
2l8uburn, I'm trying to do the same as you, tap into the factory rear speaker wires with a line output convertor to supply a signal to my amp then send a little power to a bass tube I have under my rear seat. I didn't do it yet, because I don't know the colors of the rear speaker wires either. When I get a couple of free hours I'll take off my rear door panels and check the color of the wires to make sure I'm tapping into the right wires. So if you get yours hooked up before mine, post your results here, and I'll do the same. Later.
01 Oxford White Screw
5.4L w/t 3.55 ls
ORP w/t 17 tires & skid plates
Tow pkg w/t FREE small rad
Westin Cab steps
sliding rear window
SuperChips flip chip
AirForce One FIPK
Fosgate amp
Bazooka bass tube
Rhino Liner
Lund trident bug deflector
Ravin Z55 duals at 45 degrees out the back
Husky mud flaps
Ventvisor vent shields
Warn XD9000i w/t multi-mount
cranked torsion bars
view my gallery
http://www.f150online.com/galleries/...y.cfm?gnum=745
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
