F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Aftermarket
Thread Tools Display Modes
Old 11-07-2009, 10:23 AM
Front Headlights
Folks,
I have an 05 4x4 supercrew and sometime spend time in the country with poor lighting. I noticed there's been a new type of brighter light on the road this past few years (mostly on high end cars). I don't know what they are called but it's a clearer light.
Are there any kits for my truck to upgrade the front headlight assembly? or is it just a bulb?
Thanks in advance.
E.
Old 11-07-2009, 12:25 PM
Vehicle: 2009 Ford F-150
High Intensity Discharge
Old 11-07-2009, 04:09 PM
Vehicle: 05' F150 FTX
search in the "Appearance Parts" section and they are everywhere... LOTS and LOTS of discussions on them on this forum recently. just if you get them, make sure to aim them a little lower than normal... they are bright!
Sig done by Screen-fx.net
Quote:
Originally Posted by LoneRanger93 View Post
I like it, I'm always a fan of little touches like that, which will probably be noticed by 1% of the masses, but truck guys always pick up on it!
Old 11-07-2009, 05:04 PM
Thanks guys, much appreciated.
Old 11-09-2009, 08:02 AM
Wooooonn
____________
medical SEO | doctor website | medical practice marketing
Old 11-09-2009, 08:41 AM
Goat Herder Extraordinaire
Vehicle: 1999 Ford F150
Quote:
Originally Posted by doctorweb View Post
...Are there any kits for my truck to upgrade the front headlight assembly? or is it just a bulb?
Replaced a headlamp that was out on a vehicle this weekend.
It's just the bulb, simple process.
The auto parts store had four different 'grades' of replacement bulbs.
The oem was $10.
The top of line 'bright' bulb was $25.
If you switch, you need to do both so it's probably a $50 mod.
I don't know if you have to do the high beams too, which would bump it to $100. (?)
I got the $10 bulb and got the hell out of there.
Old 11-09-2009, 10:34 AM
Vehicle: 2008 ford f150
Send a message via AIM to timmypstyle
Quote:
Originally Posted by Bouffi View Post
Folks,
Thanks in advance.
E.
yes there are many different headlight assemblies, HIDs are the bright ones you mentioned and yes there are kits but i know someone who has a HID conversion kit on his grand prix and they get hot enough to melt the lense if you are sitting still too long. they also have coolers for them, which he ended up getting also. also there are bulb upgrades. find some "sylvania silverstar headlights" yours are H13 or 9008(exact same bulbs) the silverstars are the brightest you can get before going to HIDs for your truck. there are also silverstar ultras but they do not make them in the style you need. also there are different headlight assemblies. you can go for harley davidson headlights, which are like yours only they are black or go on ebay and search for "projector headlights". i wanted the harley ones and ended up finding the ones in my sig.
thanks to dirtyd88 for the sig
LOVIN THE HALOS!!!
BEST 1/4 MILE TIME SO FAR-16.9378@81.66mph
2008 F150 reg cab shortbed 2wd 4.2L V6 5spd manual 3.55LS rearend Hancook Dynapro AS 235-70-R17
MODS-K&N 77series CAI with helper tube from front bumper.
Old 11-09-2009, 10:49 AM
you can also search on ebay for "halos" which is the ring around the headlight like i have or aka "angel eyes". angel eyes are usually smaller and not as bright. they are like what you see on BMWs and stuff. halos are bigger like mine and also the new camaro has them. but anyways if you search for halos, most of them are used on projector headlights so you will find both either way. also, usually projectors use the stock bulbs, mine did anyways except in PA where i live the side marker light has to be amber, mine was a white bulb with an amber cover, but my new ones had a clear cover so i had to get amber bulbs, but they are direct replacements. i got the silverstars in my projectors and they are bright. had to lower them because they were too high. normal headlights like yours have the bulb inside a little reflector cap which relects on the bigger reflector which reflects the light out on the road. projectors have a half circle magnifying glass almost, instead of that little cap so the light from the bulb goes thru this magnifying glass and also on the bigger reflector part. the bigger reflector is for shorter distances away while the magnifying glass projects the light farther out. but it is shot out in almost all directions which also means up, into the eyes of oncoming cars so you have to lower them, which on mine was easy. or if you really want to, you can take apart your headlight assemblies and paint the chrome to whatever color you want for a more custome look. i have seen red ones on a red truck on here. his were the same color as his truck. he was debating on black or the red of his truck. i dont have a pic of what he has but i customized his on a computer program so it was the best of both worlds. a cherry metallic red, red like his truck and also with the shadowy look of the black but also all custom. here is after my mod i showed him. its all up to you and your imagination...
LOVIN THE HALOS!!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
