F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Aftermarket
Thread Tools Display Modes
Old 07-01-2009, 01:41 AM
Vehicle: 2001 Ford F150
Ford sercuity alarm trouble...
Well I'm computerless so this is via my Palm so I'll make it short and sweet. I'm having trouble with my Ford alarm (the upgrade one that actually chirps and has motion sensors) and can't seem to get the dang thing to arm. I've taken my dash apart, checked fuses, messsed with everything, no dice. Most I've gotten it to do is chirp and unchirp but still no arm. It did arm one time and go off but then stopped after that. My mechanic said he's not to familiar with them but could look to fix it (since it stopped working after he took the dash out to replace the heater core) if I had a manual for it. No manual. So I'm just trying on my down time.
So to my question, if I go to a junk yard and find a new alarm module, could I just try it or are they vin locked?
If anyone has any suggestions on how to fix or reset the one I have now I'm more than open to any ans all suggestions. I'm just stumped right now and so was my certified Ford mechanic.
P.S.- if I take the fuse out, it chirps, then goes off when I put it back in, then I have to turn the truck on to make it stop. it then does a series of about 15 chirps and stops. Still doesn't work after that.
-Lincoln
EDIT: its a 2001 5.4 Sport if that matters.
Old 07-01-2009, 05:15 AM
Vehicle: 2007 Ford F-150
I had a similar problem with mine. The alarm stopped working but the keyless entry and chirping still worked. Well come to find out I put it in valet mode via the ignition switch. On mine if you put in the key and turn it to ON (don't start the engine) and the OFF quickly three times in a row it would activate valet mode. Just do the same thing to take it out of valet mode and back into alarm mode.
Also, if you do find another module in a junk yard, make sure it's the exact same model number. Different models can use different wires in the harness to do different things. Otherwise you might let the smoke out of your wires
Hope this helps you out...
-2007 F-150 XLT SuperCrew 4x4 5.4L 6.5' Bed
-Bilstein 5100's All The Way Around, Front set at 2" lift
-Gryphon, custom tuned by Bill at PHP
-AirAid CAI
-Flowmaster 3" Cat-Back with 50-series (thinking of changing to a 40-series or a Magnaflow)
-Wig-Wag Headlights and Tail Lights
-Line-X
Old 07-01-2009, 08:57 AM
Vehicle: 2004 Ford F-150
Also, finding one at a JY might be a long shot. I wasn't even aware that these were available back then. Not that I am some sort of Ford guru, but I am sure it would have been discussed on here more often if it was more common. Sounds like it just needs to get removed.
PHP Gryphon, 2.5" AS level, Strobes on all 4 corners, Black TS Toolbox, 15% tint all around, Pioneer AVH-P4100 with Low_e_red's relay bypass, MA Audio 1000w RMS 1 ohm amp pushing 2 - 10" ED subs under the rear seat, Viper 5901 with 530T auto up/down windows, Viair 380c at 165/200 PSI in a 3 gal tank pushing 1/2" DOT airline to my Siege Engineering train horns, and Beltronics RX 65 pro to keep me out of trouble
Old 07-01-2009, 09:08 AM
Thanks guys. I'll try the valet thing. I just would really like to keep the alarm. It seemed like a very good unit when it was fully funtional and I don't have the cash to spend on a new system.
Old 07-01-2009, 09:11 AM
Yetti, it was an upgrade option that a lot of people didn't even know was available. It would not be installed at the factory, your dealership had to install it if you wanted. Thus they would make more money by selling you one without it due to the laor to put the system in. I'd bet people weren't even told about the system 80% of the time.
Old 07-01-2009, 09:52 AM
I got it fixed. Ended up not having to try the valet mode. What did it for me (and anyone else having problems can try) is taking out the 2 20amp fuses and replacing them in a different sequence than what I was. I knew that one fuse when taken out and put in would make the alarm go off. So that's what I'd been doing. This morning, I took both fuses out, put the other fuse in (not the one that made it go off). Silent. I expeted that. I then put the other fuse, the one that had normally set off the alarm. Silent. Not expeted. But the red indicator light then started to blink fairly quickly. So I wondered....could it be that easy. Sure deal, everything is fully functional again. Thanks for the responses guys and I hope this ends up helping someone. If anyone has any questions about what's under their dash I an help with that now too...I had a baby blue color pencil that I never knew Ford put in. Haha.
Old 07-01-2009, 01:03 PM
dealerships installing actual alarms? sounds a lil scary to me. i bet they used t-taps huh?
- 285/70/17 BFG ATKO - AVIC N3 - Infinity Kappa - Infinity 475A - Magnaflow SIDO -
- Magnaflow Hiflow's - Volant CAI - Lightning Heads - LED Corners - Security by Viper -
MECP Certified Geek Squad Autotech
CEA# 174955
Give a n00b the answer he will be learn for a day; show him the search button, he will learn for life.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
