F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Other Aftermarket
Thread Tools Display Modes
Old 06-20-2009, 12:26 AM
Vehicle: 2001 Ford F150
Efan Question
I went to a local junkyard and pulled a dual efan setup out of a 1996-1999 Mercury Sable. Everything is in good running order and from what I know these fans are set up as pullers. Well I get back to the house and get the stock mechanical fan off and I go to mock fit the fans and find out I can't set them up as pullers because the hub of the efans sticks out about half an inch past the shroud. So if I tried to mount them as pullers the hub of the fan would've been in full contact with the radiator and would have made it so when the fans tried to kick on, there would've been no way they could spin due to the pressure from the mounting rods holding pressure. I have them mounted so they actually pull air from the engine bay and push it through the radiator towards the front of the truck because this was the only way I could mount them. My question is this basically, is this bad and will it cause me problems? I know alot of people say that as long as you don't block the front of the radiator you'll be fine because alot of cooling will coming from just driving. I asked this same question over at V6F150.com and nobody is giving me an answer and I need to get this resolved because worrying sucks!
Old 06-20-2009, 12:59 AM
Vehicle: 2008 FORD F150 60th Anv.
Yes you will have problems. You want cool outside air to pass thru the rad. Not hot engine bay air. If the fans do come on while driving they will be fighting the air coming in the front of the vehicle.
Old 06-20-2009, 01:01 AM
Is there any way you can space the fans away from the rad?
Old 06-20-2009, 01:14 AM
I imagine I could space them by fabbing up some spacers. I need to think up something I can use as spacers. I need them to be 1/2 - 3/4" thick and probably the size of a quarter each. I don't want to use washers, preferably a hard plastic.
This is on a V6 motor by the way. I have a buddy who says his efans only cut on while he is idling so I figure if I can't fab up the spacers immediately I should be ok for a little bit.
Old 06-20-2009, 01:23 AM
You said mounting rods. Are mounting them by using rods going thru the rad fins? If so that is a bad idea. Have seen many postings about the rods rubbing holes in the rad tubes causing leaks.
Old 06-20-2009, 01:27 AM
Yea, that's what I'm using. What do you recommend?
Old 06-20-2009, 01:36 AM
wrong fan,you should of pulled one out of a 91ish model with a 3.8 that that is the powerfull one.
Old 06-20-2009, 01:40 AM
Well if anything, I'll just go back to the junkyard and snag one of the 18" fans out of a Thunderbird..this time I'll check the thing out before getting super giddy about it. I'll retrofit these fans to make them work. Once I get the bigger fan mounted and running I'll just sell my current ones. It shouldn't be too much of a PITA to swap out because A.)Mechanical fan will be already out and B.)Controller is already wired up. Undo the old fan, clip the two wires, swap the fans out, rewire the single fan.
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
if they are blowing backwards from inside out, reverse the polarity of the wires going into the fans
Old 06-20-2009, 01:43 AM
It'll work even though they are Ford fans? I said I could reverse the polarity of the fans to Raptor and he said that wouldn't work. I told him I was pretty sure it would work.
Old 06-20-2009, 01:51 AM
Would depend on the shape of the blades. Some are designed for max air flow in one direction only.
Old 06-20-2009, 01:55 AM
right, any motor will spin either direction depnding on polarity, but you need to flip the blade over if its not a universal
Old 06-20-2009, 01:59 AM
Well, the blades on the fans I have are definitely not able to be flipped over
Problem fixed. Thanks for that tip, Patman
Old 06-24-2009, 12:13 AM
well I bought a used fan out of a 03 crown vic police car, seems pretty powerfull but you would have to remove the rad and do some cutting and making of brackets to ke it fit, but the fan is still 2 inches too tall for our trucks, that's why i installed a tarus fan.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
